    CentOS2Alma discussion
Quota problem on Plesk 8.0.1 and FC4
X
xtreme2490
In my Plesk CP in Physical Hosting setup , it say's harddisc quota is not supported.
However :
etc/fstab
LABEL=/ / ext3,usrquota defaults 1
/usr/local/psa/admin/sbin/usermng --isquotable
usermng: File system ext3,usrquota has no quota support.
System error 2: No such file or directory
1
What is wrong , how can i solve it ?
I got it working...
I added the quota to the /etc/fstab like following line:
/dev/VolGroup00/LogVol00 / ext3 defaults,usrquota,grpquota 1 1
Then I got to the filesystem where you want quotas on (/var/www/vhosts, in my case a have a Logical Volume mounted over /var/www , but if you have a typical FC4 installation it can be /)
do the following:
touch /aquota.user /aquota.group
chmod 600 /aquota.*
mount -o remount /
quotaon -avug
The last line isn't necaisary i guess because you added usrquota and grpquota to the fstap by yourself.
After doing this quotas were working !!
Got it to work to , it was the first line in fstab.
I've changed it like the kb from swoft , and now it works.
