    CentOS2Alma discussion
Serious Problem!
A
awpti
Went to update from 7.5.6 to 7.6
Install was stuck on "Applying Security for c:\" for over 4 hours.
I decided to cancel and let it roll back the changes.. it's still stuck there. This server is hosting 160 sites and they are ALL down right now.
I don't know what to do.
Anyone?
It finally canceled but did NOT roll back.
I was sent some fix information by SWSoft Techs but it is, yet again, stuck on permissions and my websites are STILL down. Each domain is asking for a login/password when we try to view their website.
Example;
www.acklinsislandlodge.com
www.awpti.org
the plesk reconfigurator / Disk Permissions utility has been sitting at 00:00 time remaining for over an hour. It appears to be doing nothing.
Before you update the webserver you'd probably made a backup, then i would recommend to reinstall windows en restore the backup. Then you're websites are back online and then you can investigate the problem without pressure.
I made the unfortunate presumption that SWSoft actually tests their releases for upgrades.
This is apparently a known issue.
Have you selected to install Apache Tomcat? If yes, try upgrading without Tomcat.
The upgrade installer gave no options for what to/not to install..
Still running the Check&Repair tool.
Hopefully when it's done, websites will be working.
Same problem here with my biggest server, hosting more than 400 domains.
I'mg going to wait.
