SugavanasS
Basic Pleskian
Hello,
i have a vps with plesk installed. The vps has only one IP. So now i have my domain, example.com.
It's in namecheap and i have setted up nameserver records, ns1.example.com and ns2.example.com [both pointing to that one IP]
when i point another domain to that nameservers, i directly get
This web page is not available
Less
The web page at http:/example1.co/ might be temporarily down or it may have moved permanently to a new web address.
Error code: ERR_NAME_RESOLUTION_FAILED.
I don't really know why ?
But when i edit the dns record of that example1.co to point to my ip, i get to see the plesk default page.
Before when i was running cpanel on reseller hosting, i did the same way of editing my nameservers ip to one same ip and it worked.
Is it a problem with 1 IP ? Should i have more IPS ? Is there a place to set the nameservers in Plesk ? Like in WHM, it needs to be set in account someplace :O
Please i need help, i got the same problem when using Zpanel. I even tried adding nameservers in my other domains but still no luck :/
Less
