H
hostshelter
Hi Everybody,
I'm trying to shed some light to the problem of sitebuilder 2.0 installation.
All the rpm were installed fine but when i try to finish the installation at:
http://sitebuilder.mydomain.com/install/install.php i get the following error:
Process of installation has come to the end with failure. Database tables
have not been created...
Please, check it...
Details see in /usr/local/sitebuilder/log/install.log file.
and my install.log is as follow:
[9-June-2005 1:52:22] Log of installation process
[9-June-2005 1:52:22] Create dirs...........
[9-June-2005 1:52:22] The dir "temp" is created ...Ok
[9-June-2005 1:52:22] The dir "users" is created ...Ok
[9-June-2005 1:52:22] Create config file..........
[9-June-2005 1:52:22] Unlink file
"/usr/local/sitebuilder/include/config.php"
..... Ok
[9-June-2005 1:52:22] Process sql-query: USE sitebuilder[9-June-2005
1:52:22] Result:...... Error: (code=)
[9-June-2005 1:52:22] Error on query >> USE sitebuilder
[9-June-2005 1:52:22] Process sql-query: CREATE DATABASE
sitebuilder[9-June-2005 1:52:22] Result:...... Error: (code=)
[9-June-2005 1:52:22] Error on query >> CREATE DATABASE sitebuilder
[9-June-2005 1:52:22] Create DataBase "sitebuilder"..... fail
[9-June-2005 1:52:22] Create tables...........
[9-June-2005 1:52:22] Process of installation has come to the end with
failure.
Database tables have not been created... Plea se, check it...
I had Sitebuilder 1.1.1 before but i upgraded my plesk reload 7.5.3 control
panel yerterday to include the sitebuilder module and since then it stop
working so i uninstall the SB 1.1.1 and install SB 2.0 from scratch.
I've been trying for hours to get this SB 2.0 to work but not luck.
I would appreciate any help with this issue.
Thanks
Miguel
Please, check it...
..... Ok
failure.
Thanks
Miguel
