    CentOS2Alma discussion
SSL cert problem
A
a2tech
I installed an SSL cert for one of my domains. The site runs Mambo, which was originally installed in the httpdocs folder. I would like to run https with some parts of it.
Do I have to reinstall it in the httpsdocs folder or is there some way to use Plesk to serve the SSL linked docs from the same httpdocs folder?
In the Plesk control panel, goto <DOMAINS><DOMAINNAME><SETUP> Check the box for SSL in same folder as httpdocs
When I go to Domains, then choose the Domain name, the only Setup icon is for the physical hosting. If I choose that, the only SSL options I see is "SSL Support". It does not mention which folders will be covered by SSL.
In the list of Domain icons for my domain, which area am I supposed to go into?
the difference must be the version of Plesk that you are running. I have Plesk 7.5.4. My options in the physical hosting setup say:
SSL support
Use a single directory for housing SSL and non-SSL content
I don't know if that option is available in older versions.
Ah, ic.
I was going to upgrade, but I am running a different verison of Mambo than the one that comes w Plesk. When I tried to upgrade Plesk, it wanted to upgrade Mambo, so I canceled it.
Hmmm, will have to figure out how to upgrade I think.
Thank you.
I'm sure there has to be an "alias" command in one of the conf files. Before you try upgrading ( unless you really want to upgrade ), let's see if I can find the answer or maybe someone else will chip in with the answer for us.
a2tech,
From what I could find out, the settings are in the httpd.include file in the /home/httpd/vhosts/domainname/conf directory. The problem is that Plesk over writes this file whenever an upgrade is done. If you do not want to upgrade to 7.5.4 now but are planning to in the future, you could edit this include file to change the ssl directory, but this is not a perament fix as this file may get updated by Plesk.
Thanks
I will look there. I can always add this note to my "playbook" for Plesk in case I upgrade.
