1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
  2. Dear Pleskians, please read this carefully! New attachments and other rules Thank you!
    Dismiss Notice
  3. Dear Pleskians, I really hope that you will share your opinion in this Special topic for chatter about Plesk in the Clouds. Thank you!
    Dismiss Notice
Unable to view web stats
Discussion in 'Plesk for Windows - 8.x and Older' started by mab65, Jan 18, 2006.
  1. mab65
    mab65 Guest
    When I try to view my sites web stats the following message is displayed - "This is the placeholder for Web statistics. If you see this page that means that statistics service has not run yet on your server. Statistics service is typically set to run once every 24 hours. If you do not see a change to this page in the next 24 hours contact your server administrator for assistance. "
    Could some one please tell me how to enable this service. Many thanks.
  2. swarm
    swarm Guest
    Default placeholder for statistics indicates that statistics was not calculated yet. Statistics calculates by scheduled running statistics.exe utility. You can run it manually to force statistics calculation.
  3. mab65
    mab65 Guest
    Thanks for that swarm. How do I manually run it though?
  4. xandih
    xandih Guest
    %plesk_bin%\statistics.exe ;)
  5. mab65
    mab65 Guest
    Thanks both. All sorted now.
  6. evslanca
    evslanca Guest
    did I try to do that, but even so, doesn't it work, what to do?
  7. xandih
    xandih Guest
    run it in cmd, if doesn't work, you'll see an error
Loading...
