Hello,
I'm trying to upgrade SB from version 2.1.3 to 3.0.2 but it is not working.
I have a RHEL3 test system with all packages updated (with RH's up2date).
I have installed Plesk 7.5.4 in this server, and it is also updated.
Then I have installed SB 2.1.3 with all modules and templates.
At this point the system was working perfectly, everything was working fine.
Since this is a test server, it does not have Plesk's or SB's licence keys.
There was no data in SB, despite 3 or 4 "test" sites I have made myself while testing the installation.
Then I have downloaded the SB 3.0.2 installation package and modules (sitebuilder-3.0.2-rhas3.build06112310.tar.gz).
Notice that the package says RHAS insted of RHEL, but this is the package available for download at SwSoft's site at the RHEL3 section.
I have noticed that the 3.0.2 version requires you to uninstall the 2.1.3 version modules, since there was some RPM dependancies.
I have uninstalled all 2.1.3 "modules" with "rpm -e".
I have also uninstalled the SB 2.1.3 remote admin package.
Then I have installad all 3.0.2 packages with the "rpm -hUv *.rpm" command from the SB3's packages directory.
Everthing seems to work fine during the installation, no error messages was displayed at the screen or log file.
At this point I have tried to access the SB site, but it didn't work.
I received this error messages:
Warning: Unknown(/usr/local/sitebuilder/include/autoprp.php): failed to open stream: No such file or directory in Unknown on line 0
Warning: (null)(): Failed opening '/usr/local/sitebuilder/include/autoprp.php' for inclusion (include_path='.:/usr/local/sitebuilder/include/:') in Unknown on line 0
The file that is being included in the index.php file ("usr/local/sitebuilder/include/autoprp.php") does not exist.
The I have tried to acess the admin pages, but I received a 404 error message.
I have looked at the filesystem, and there is no "/usr/local/sitebuilder/htdocs/admin" directory at all!
Then I have installed SB3's modules and templates, but nothing has changed.
I have run the "sb_config" and "sb_config --migrate_all" commands, and both run without errors:
#sb_config
Update SiteBuilder database user credentials: ...Ok
Templates have been updated.
Memory limit has been updated.
Locales have been updated.
Modules have been updated.
Reconfiguration has been finished.
...Detailed log has been saved to /usr/local/sitebuilder/tmp/sb_config-0612292319.log
# sb_config --migrate_all
Migration process started:
Done.
I have made all the steps above a few times again, reinstalling everything from scratch, changing the order of some steps sometimes, but always with the same result.
It looks like the installation packages (for RHEL3 maybe?) are broken.
Can someone help me with this issue?
Thank you!
Alexandre
#sb_config
Done.
Thank you!
Alexandre
