1. Please take a little time for this simple survey! Thank you for participating!
    Dismiss Notice
Urgent: Plesk Backup DB Problem. Need Help
Discussion in 'Plesk for Linux - 8.x and Older' started by ThE-KinG, Jul 31, 2005.
  1. ThE-KinG
    ThE-KinG Guest
    Plesk backup gives that error.
    Code:
    An error occured during backup process:
    DBI connect('host=localhost;database=psa;mysql_socket=/var/lib/mysql/mysql.sock','admin',...) failed: Client does not support authentication protocol requested by server; consider upgrading MySQL client at /usr/local/psa/lib/perl5/BU/DB.pm line 38
    Unable to connect to mysql
    System:
    FreeBSD, mySQL 4.1.9
    Plesk 7.5.3
    Perl Lib 5.8.6
    How can I fix this error? Thank you sooo much for your help.
  2. ThE-KinG
    ThE-KinG Guest
    Hey friends look here I need help :(
  3. mikk
    mikk Basic Pleskian
    23
    73%
    Jan 29, 2005
    83
    Have you recently updated the server mysql-client to 4.1.9?
    if so have you updated the perl DBD items?
    perl -MCPAN -e "force install DBD::mysql"
  4. hardweb
    hardweb Guest
    You must add to my.cnf:
    old-passwords
    in the [mysqld] context and the application that tries to connect to the database will work.
  5. ThE-KinG
    ThE-KinG Guest
    Thank you friends for all replies.
    I have done this. The result is:
    Code:
    CPAN: Storable loaded ok
    Going to read /root/.cpan/Metadata
      Database was generated on Mon, 27 Jun 2005 16:58:29 GMT
    DBD::mysql is up to date.
    hardweb, I have tried to add old-passwords in my.cnf but the error is same and continue.
    Many thanks and any other ideas?
  6. JROnline
    JROnline Guest
    The problem seems to be coming from the location where the mysql.sock is located.
    If you check the file:
    and search for the location of mysql.sock:
    $socket_path='/tmp/mysql.sock'; # default path
    return "$socket_path" if ( -e "$socket_path") ;
    $socket_path='/var/lib/mysql/mysql.sock'; # default path
    If you comment out the first location, the backup works again.
  7. ThE-KinG
    ThE-KinG Guest
    Thanks I have done this but the error continue.
    Code:
    I have changed like this:
    Code:
    #$socket_path='/tmp/mysql.sock'; # default path
    #return "$socket_path" if ( -e "$socket_path") ;
  8. idle
    idle Guest
    I got same problem. I tried to upgrade client but all attempts failed with different errors. When I tried to install from ports(mysql41-client,mysql50-client), it say "make: cannot open Makefile".
    Any ideas?
    FreeBSD5.3
    mysql Distrib 4.0.16
    Plesk 7.5.4
  9. Stucco
    Stucco Guest
    Same error here any answer yet?
    Code:
    Attempt to connect to MySQL server ... DBI connect('host=localhost;database=psa;mysql_socket=/var/lib/mysql/mysql.sock','admin',...) failed: Client does not support authentication protocol requested by server; consider upgrading MySQL client at /usr/local/psa/lib/perl5/BU/DB.pm line 38
    failed
    Notice it is finding the correct mysql.sock location in the error, also I have old_passwords=1.
  10. jeremycohoe
    jeremycohoe Guest
    Old mysql version error
    Hello,
    I was having this problem and have figured out a solution. I hope it works for anyone else having this issue.
    I had to go into Server > Change password and change the 'admin' user's password. I changed it to the same password it was before, but in doing so, I guess that fixed the error I was getting, which was:
    Attempt to reconnect to MySQL server ... DBI connect('host=localhost;database=psa;mysql_socket=/tmp/mysql.sock','admin',...) failed: Client does not support authentication protocol requested by server; consider upgrading MySQL client at /usr/local/psa/lib/perl5/BU/DB.pm line 38
    Unable to connect to PSA database.
    Good luck,
Loading...
