    CentOS2Alma discussion
Webmail problem
E
ecja
Webmail on a new install FedoraCore 3
A fatal error has occurred
DB Error: extension not found
Details have been logged for the administrator
Nothing in /var/log/messages
See below for
cat /usr/local/psa/var/log/maillog:
Dec 26 04:11:49 ns1 qmail: 1135588309.751714 new msg 2590975
Dec 26 04:11:49 ns1 qmail: 1135588309.751957 info msg 2590975: bytes 2361 from <#@[]> qp 16734 uid 2522
Dec 26 04:11:49 ns1 qmail: 1135588309.770538 starting delivery 67: msg 2590975 to local [email protected]
Dec 26 04:11:49 ns1 qmail: 1135588309.770668 status: local 1/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.770769 new msg 2590998
Dec 26 04:11:49 ns1 qmail: 1135588309.771785 info msg 2590998: bytes 1275 from <#@[]> qp 16732 uid 2522
Dec 26 04:11:49 ns1 qmail: 1135588309.786539 starting delivery 68: msg 2590998 to local [email protected]
Dec 26 04:11:49 ns1 qmail: 1135588309.786728 status: local 2/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.786792 delivery 67: failure: This_address_no_longer_accepts_mail./
Dec 26 04:11:49 ns1 qmail: 1135588309.787200 status: local 1/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.787305 triple bounce: discarding bounce/2590975
Dec 26 04:11:49 ns1 qmail: 1135588309.787462 end msg 2590975
Dec 26 04:11:49 ns1 qmail: 1135588309.787979 new msg 2590999
Dec 26 04:11:49 ns1 qmail: 1135588309.788203 info msg 2590999: bytes 1810 from <#@[]> qp 16738 uid 2522
Dec 26 04:11:49 ns1 qmail: 1135588309.799529 starting delivery 69: msg 2590999 to local [email protected]
Dec 26 04:11:49 ns1 qmail: 1135588309.799719 status: local 2/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.799783 delivery 68: failure: This_address_no_longer_accepts_mail./
Dec 26 04:11:49 ns1 qmail: 1135588309.800029 status: local 1/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.800110 triple bounce: discarding bounce/2590998
Dec 26 04:11:49 ns1 qmail: 1135588309.800177 end msg 2590998
Dec 26 04:11:49 ns1 qmail: 1135588309.801792 new msg 2590971
Dec 26 04:11:49 ns1 qmail: 1135588309.801960 info msg 2590971: bytes 13956 from <[email protected]> qp 17379 uid 0
Dec 26 04:11:49 ns1 qmail: 1135588309.831609 starting delivery 70: msg 2590971 to local [email protected]
Dec 26 04:11:49 ns1 qmail: 1135588309.831799 status: local 2/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.831863 delivery 69: failure: This_address_no_longer_accepts_mail./
Dec 26 04:11:49 ns1 qmail: 1135588309.832115 status: local 1/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.832192 triple bounce: discarding bounce/2590999
Dec 26 04:11:49 ns1 qmail: 1135588309.832267 end msg 2590999
Dec 26 04:11:49 ns1 qmail: 1135588309.839044 delivery 70: failure: This_address_no_longer_accepts_mail./
Dec 26 04:11:49 ns1 qmail: 1135588309.839623 status: local 0/10 remote 0/20
Dec 26 04:11:49 ns1 qmail: 1135588309.860588 bounce msg 2590971 qp 17788
Dec 26 04:11:49 ns1 qmail: 1135588309.860880 end msg 2590971
Dec 26 04:36:50 ns1 qmail: 1135589810.634421 new msg 2590999
Dec 26 04:36:50 ns1 qmail: 1135589810.634622 info msg 2590999: bytes 14492 from <> qp 17788 uid 2522
Dec 26 04:36:50 ns1 qmail: 1135589810.642127 starting delivery 71: msg 2590999 to local [email protected]
Dec 26 04:36:50 ns1 qmail: 1135589810.642310 status: local 1/10 remote 0/20
Dec 26 04:36:50 ns1 qmail: 1135589810.650401 delivery 71: failure: This_address_no_longer_accepts_mail./
Dec 26 04:36:50 ns1 qmail: 1135589810.650973 status: local 0/10 remote 0/20
Dec 26 04:36:50 ns1 qmail: 1135589810.685260 bounce msg 2590999 qp 18067
Dec 26 04:36:50 ns1 qmail: 1135589810.685558 end msg 2590999
Dec 26 05:01:51 ns1 qmail: 1135591311.349995 new msg 2590975
Dec 26 05:01:51 ns1 qmail: 1135591311.350240 info msg 2590975: bytes 14944 from <#@[]> qp 18067 uid 2522
Dec 26 05:01:51 ns1 qmail: 1135591311.357734 starting delivery 72: msg 2590975 to local [email protected]
Dec 26 05:01:51 ns1 qmail: 1135591311.357928 status: local 1/10 remote 0/20
Dec 26 05:01:51 ns1 qmail: 1135591311.364946 delivery 72: failure: This_address_no_longer_accepts_mail./
Dec 26 05:01:51 ns1 qmail: 1135591311.365524 status: local 0/10 remote 0/20
Dec 26 05:01:51 ns1 qmail: 1135591311.365626 triple bounce: discarding bounce/2590975
Dec 26 05:01:51 ns1 qmail: 1135591311.365780 end msg 2590975
I check every thing here but they are ok
http://faq.sw-soft.com/article_50_940_en.html
It is not a password issue it seems, the http://webmail.xxxxxxxx.com gave this error without the horde
This what in the var/log/psa-horde
Dec 26 13:21:53 HORDE [emergency] [horde] DB Error: extension not found: mysql, , /var/lib/mysql/mysql.sock, unix, localhost, horde, horde, iOHl4V31zcmHP, utf8, horde, horde.perms, horde_datatree, horde_datatree_attributes [on line 1329 of "/usr/share/psa-horde/lib/Horde/DataTree/sql.php"]
Hello, according to Flesk support
the php-mysql rpm package not installed.
Do any one know where to downlaod it and how to installed it
The server has
PHP Version 4.4.1
mysql-4.4.1l
I faced the same problem but the instructions http://faq.sw-soft.com/article_50_940_en.html on didn't help.
What I found was that somehow PHP couldn't find the extensions because the directory was not set properly.
On /etc/php.ini, change
extension_dir = "./"
to
extension_dir = "/usr/lib/php4/"
and restart httpd with
service httpd restart
Version information
CentOS release 4.3 (Final)
psa-7.5.4-rhel4.build75050824.12
php-mysql-4.4.2-3.rhel4.art
php-4.4.2-3.rhel4.art
mysql-4.1.18-1.rhel4.art
Hope it helps.
