    CentOS2Alma discussion
  • Please beaware of a breaking change in the REST API on the next Plesk release (18.0.62).
    Starting from Plesk Obsidian 18.0.62, requests to REST API containing the Content-Type header with a media-type directive other than “application/json” will result in the HTTP “415 Unsupported Media Type” client error response code. Read more here
Issue Directadmin to Plesk Migration problem
simoncsc
CentOS Linux release 8.5.2111
Plesk Obsidian v18.0.59_build1800240226.11 os_Debian 12.0
hello
My Directadmin OS version is "CentOS Linux release 8.5.2111"
I can ssh to my Directadmin server via putty with root account
Now I am tring to migrate my current Directadmin to Plesk via plesk tools "Migration & Transfer Manager", but I got below error before it starts:
Failed to deploy Python on source server
Cause: Error while connecting to the the source server 'directadmin' (IP Address) at 'IP Address' by SSH as 'root': Unable to connect to 'IP Address' by SSH: [Errno None] Unable to connect to port 14686 on IP Address.
Ensure that the server is up and there are no firewall rules that may block SSH connections to the server,
then restart migration.
That is a critical error, migration was stopped.
Thank you for letting us know, but in this case it seems to be an issue on the source server or its firewall that does not let SSH through.
2. Edit the following file on the target(Plesk) server:
/usr/local/psa/admin/plib/modules/panel-migrator/backend/lib/python/parallels/plesk/source/custom/actions/deploy_migrator_python.py
Append the (OSName.OS_CLOUDLINUX, '8'): 'PMM_0.1.11', line as follows:
redhat_oses = {
(OSName.OS_CENTOS, '5'): 'PMM_0.1.10',
(OSName.OS_CENTOS, '6'): 'PMM_0.1.11',
(OSName.OS_CENTOS, '7'): 'PMM_0.1.11',
(OSName.OS_CENTOS, '8'): 'PMM_0.1.11',
(OSName.OS_RHEL, '5'): 'PMM_0.1.10',
(OSName.OS_RHEL, '6'): 'PMM_0.1.11',
(OSName.OS_RHEL, '7'): 'PMM_0.1.11',
(OSName.OS_RHEL, '8'): 'PMM_0.1.11',
(OSName.OS_CLOUDLINUX, '5'): 'PMM_0.1.10',
(OSName.OS_CLOUDLINUX, '6'): 'PMM_0.1.11',
(OSName.OS_CLOUDLINUX, '7'): 'PMM_0.1.11',
3. Re-Run the migration.
In your case make sure that the RHEL 8 line exists.
redhat_oses = {
Still same issue after added the line.
After added the line, the error message is little diffrence before
Cause: Command execution failed on the local server with non-zero exit code.
command: rsync -l --chmod=Fu=rw,Du=rwx,go= --timeout=30 -e 'ssh -i /usr/local/psa/var/modules/panel-migrator/sessions/20240305175030/ssh-keys/id_rsa.IP addres -p 8022 -o PasswordAuthentication=no -o StrictHostKeyChecking=no -o GSSAPIAuthentication=no' /usr/local/psa/var/modules/panel-migrator/sessions/20240305175030/ssh_upload.1 root@IP addres:/etc/yum.repos.d/plesk-migrator.repo
exit code: 255
stdout:
stderr: root@IP addres: Permission denied (gssapi-keyex,gssapi-with-mic,password).
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(231) [sender=3.2.7]
You mentioned that you can login to the source with PuTTY, but did you try to SSH into your source server from the target server manually, so that you can verify that basically a root login from the target to source via SSH is possible?
Yes I can login to source server via ssh command on traget server.
This is a case for a deeper investigation by support. Please open a ticket with Plesk support so that an engineer can check the issue on your server for you.
To sign-in to support please go to https://support.plesk.com
If you experience login issues, please see this KB article:
https://support.plesk.com/hc/en-us/...rt-plesk-com-and-password-reset-does-not-work
If you bought your license from a reseller, your reseller should provide support for you. If the reseller does not provide support, here is an alternative:
https://support.plesk.com/hc/en-us/articles/12388090147095-How-to-get-support-directly-from-Plesk-
