    CentOS2Alma discussion
  • Please beaware of a breaking change in the REST API on the next Plesk release (18.0.62).
    Starting from Plesk Obsidian 18.0.62, requests to REST API containing the Content-Type header with a media-type directive other than “application/json” will result in the HTTP “415 Unsupported Media Type” client error response code. Read more here
need help with script module, etc.
S
Stryke
Hi!
Can anyone here tell me if there is a way to configure the script module box? Specifically, I would like to know:
1. How to resize the script module box
2. How to move it to the right, left, or absolute center, with text wrapping around it
Also, I would like to know how to insert the Google Analytics tracking code on my site built with Sitebuilder?
Information on these issues will be most helpful and greatly appreciated.
Thank you! :)
There is no way to modify script module box or move it somewhere through Sitebuilder configuration. If you can try to check Sitebuilder Scrip module files and probably make some corrections there, but it is not recommended as it can cause module brake.
As for Google Analytics tracking code, did you try to insert it into script module directly?
I haven't tried inserting the Google Analytics tracking code yet because I wanted to clarify the issues regarding the script module box. I am afraid this would only eat up a major portion of my web pages.
Here's what I mean when I talk about re-sizing, configuring, aligning the script module box:
http://www.ziddu.com/download/2050750/sitebuilder-screenshot.jpg.html
Can this be done? If yes, how?
Unfortunately, there is no way for such changes. Actually, this window appears only in Sitebuilder Wizard. On published site script, included into module, is executed and there is no module box anymore.
