Problem while installing Plesk on Debian
B
Bluelane
I have this problem when I want to install Plesk on Debian :
Installation type
Please select the components you wish to install:
1. [*] Base packages of Plesk
2. [ ] Plesk Professional Web Site Editor
3. [=] Apache mod_python module (already installed)
4. [ ] Backup utilities
5. [ ] Plesk Counter-Strike game server module
6. [ ] Frontpage 2002 support
7. [ ] Plesk Firewall module
8. [ ] Dr. Web antivirus
9. [ ] Plesk migration manager
10. [ ] Plesk API [former Plesk Agent]
11. [ ] Plesk VPN module
12. [ ] SPAM blocker for QMail daemon
13. [ ] Plesk Battlefield 1942 game server module
14. [ ] Plesk Fileserver module and SMB file server package
15. [ ] Additional Horde (webmail) components for Plesk
16. [ ] Application vault packages
17. [ ] Watchdog (System monitoring module)
18. [ ] SSHTerm - SSH Terminal java applet
19. [ ] Mailman mailing list manager support
20. [ ] Additional Plesk manuals
21. [ ] PosgreSQL server support
22. [ ] ASP support
23. [ ] SpamAssassin support
24. [ ] Tomcat Java Servlets support
25. [ ] ColdFusion support for Plesk
26. [ ] SiteBuilder and Sitebuilder module for Plesk
1) Next page; 2) Previous page; 0) Cancel installing
3) Toggle a component; 4) Select all; 5) Deselect all;
Type the number corresponding to the desired action and press Enter [1]:
Hit http://10.94.53.49 stable/main Packages
Hit http://10.94.53.49 stable/main Release
Hit http://10.94.53.49 stable/contrib Packages
Hit http://10.94.53.49 stable/contrib Release
Hit http://10.94.53.49 stable/non-free Packages
Hit http://10.94.53.49 stable/non-free Release
Hit http://10.94.53.49 stable/non-US/main Packages
Hit http://10.94.53.49 stable/non-US/main Release
Hit http://10.94.53.49 stable/non-US/contrib Packages
Hit http://10.94.53.49 stable/non-US/contrib Release
Get:1 http://autoinstall.plesk.com PSA_7.5.4/ Packages [12.5kB]
Hit http://10.94.53.49 stable/non-US/non-free Packages
Hit http://10.94.53.49 stable/non-US/non-free Release
Hit http://10.94.53.49 stable/updates/main Packages
Hit http://10.94.53.49 stable/updates/main Release
Hit http://10.94.53.49 stable/updates/contrib Packages
Hit http://10.94.53.49 stable/updates/contrib Release
Hit http://10.94.53.49 stable/updates/non-free Packages
Ign http://autoinstall.plesk.com PSA_7.5.4/ Release
Hit http://10.94.53.49 stable/updates/non-free Release
Fetched 12.5kB in 0s (27.1kB/s)
Reading Package Lists...
Building Dependency Tree...
psa is already the newest version.
psa-api-cli is already the newest version.
psa-api-common is already the newest version.
psa-courier-imap is already the newest version.
psa-courier-imap-add is already the newest version.
psa-key is already the newest version.
psa-locale-base-en-us is already the newest version.
psa-proftpd is already the newest version.
psa-proftpd-inetd is already the newest version.
psa-qmail is already the newest version.
psa-appvault-mambo is already the newest version.
psa-appvault-oscommerce is already the newest version.
psa-horde is already the newest version.
psa-imp is already the newest version.
psa-hotfix is already the newest version.
psa-hotfix2 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
7 not fully installed or removed.
Need to get 0B of archives.
After unpacking 0B of additional disk space will be used.
Setting up psa (7.5.4-debian3.1.build75050824.12) ...
/var/lib/dpkg/info/psa.postinst: line 7580: : No such file or directory
Unable to find product configuration file: /etc/psa/psa.conf
Setting the default locale
ERROR while trying to setting default locale
Check the error reason(see log file: /tmp/psa_7.5.4_Debian_3.1_build75050824.12_installing.log), fix and try again
Aborting...
dpkg: error processing psa (--configure):
subprocess post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of psa-appvault-mambo:
psa-appvault-mambo depends on psa (>= 7.5); however:
Package psa is not configured yet.
dpkg: error processing psa-appvault-mambo (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of psa-appvault-oscommerce:
psa-appvault-oscommerce depends on psa (>= 7.5); however:
dpkg: error processing psa-appvault-oscommerce (--configure):
dpkg: dependency problems prevent configuration of psa-horde:
psa-horde depends on psa (>= 7.5.4); however:
dpkg: error processing psa-horde (--configure):
dpkg: dependency problems prevent configuration of psa-hotfix:
psa-hotfix depends on psa-7.5.4; however:
Package psa-7.5.4 is not installed.
Package psa which provides psa-7.5.4 is not configured yet.
dpkg: error processing psa-hotfix (--configure):
dpkg: dependency problems prevent configuration of psa-hotfix2:
psa-hotfix2 depends on psa-7.5.4; however:
dpkg: error processing psa-hotfix2 (--configure):
dpkg: dependency problems prevent configuration of psa-imp:
psa-imp depends on psa-horde; however:
Package psa-horde is not configured yet.
dpkg: error processing psa-imp (--configure):
Errors were encountered while processing:
psa
psa-appvault-mambo
psa-horde
psa-hotfix
psa-hotfix2
psa-imp
E: Sub-process /usr/bin/dpkg returned an error code (1)
Press <ENTER> to continue...
Had similar issues
While i did it a long time ago, (literally first day they released plesk for debian) i do recall having massive issues getting it up and running. i had installed it just one week before on redhat ES and had no issues at all.
Still glad i went through the headaches of getting it setup on debian though. If i recall i went and downloaded all of the packages and did a manual installation of each package by hand using dpkg -i <package_name>.
There were a few i had to string together to resolve dependancies and i also recall there were quite a few i had to resort to doing it with dpkg -i --force-all on a few packages. THIS CAN BE DANGEROUS. but then again so can be beating your head on the same problem for a few days.
If you do something like that, which i admit i did. backup your stuff. give yourself an exit route.
Also recommend reading up on dpkg --force-help
It will explain all of the various permutations that --force has and what is different with each ones.
Long story is it can be installed but you have to find out what the first dependancy is and string them together when installing them.
Hope that is of some help.
