Thomas Wilhelmi
Regular Pleskian
Hello,
I defined a VPN and want to use a SMB-Share across this Connection. This is more or less working (The VPN-Problem get's a new thread after this is solved). In Plesk I have this Screen in the SMB-Configuration:
That means the SMB-Server is stopped and I can activate it. But the Server is running! When I click on activate I get the message that the Server was already running but the page i unchanged. Means I get no statistics and the Activate-Button is still green.
Output in the log:
Regards
Output in the log:
Jul 31 08:35:25 h1431219 systemd[1]: Stopping LSB: Samba SMB/CIFS file and print server...
Jul 31 08:35:25 h1431219 smb[14477]: Shutting down Samba SMB daemon Warning: daemon not running. ..done
Jul 31 08:35:25 h1431219 systemd[1]: Unit smb.service entered failed state
Jul 31 08:35:25 h1431219 systemd[1]: Starting LSB: Samba SMB/CIFS file and print server...
Jul 31 08:35:25 h1431219 smbd[14496]: [2013/07/31 08:35:25.556933, 0] param/loadparm.c:7885(lp_set_enum_parm)
Jul 31 08:35:25 h1431219 smbd[14496]: WARNING: Ignoring invalid value 'none' for parameter 'printing'
Jul 31 08:35:25 h1431219 smb[14487]: Starting Samba SMB daemon ..done
Jul 31 08:35:25 h1431219 systemd[1]: Started LSB: Samba SMB/CIFS file and print server.
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.367541, 0] lib/util_sock.c:667(open_socket_in)
Jul 31 08:35:26 h1431219 smbd[14497]: bind failed on port 445 socket_addr = ::.
Jul 31 08:35:26 h1431219 smbd[14497]: Error = Address already in use
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.372524, 0] smbd/server.c:626(smbd_open_one_socket)
Jul 31 08:35:26 h1431219 smbd[14497]: smbd_open_once_socket: open_socket_in: Address already in use
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.375060, 0] lib/util_sock.c:667(open_socket_in)
Jul 31 08:35:26 h1431219 smbd[14497]: bind failed on port 139 socket_addr = ::.
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.376394, 0] smbd/server.c:626(smbd_open_one_socket)
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.376546, 0] lib/util_sock.c:667(open_socket_in)
Jul 31 08:35:26 h1431219 smbd[14497]: bind failed on port 445 socket_addr = 0.0.0.0.
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.376765, 0] smbd/server.c:626(smbd_open_one_socket)
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.376900, 0] lib/util_sock.c:667(open_socket_in)
Jul 31 08:35:26 h1431219 smbd[14497]: bind failed on port 139 socket_addr = 0.0.0.0.
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.380802, 0] smbd/server.c:626(smbd_open_one_socket)
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.380937, 0] smbd/server.c:794(open_sockets_smbd)
Jul 31 08:35:26 h1431219 smbd[14497]: open_sockets_smbd: No sockets available to bind to.
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.419024, 0] smbd/server_exit.c:168(exit_server_common)
Jul 31 08:35:26 h1431219 smbd[14497]: ===============================================================
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.419294, 0] smbd/server_exit.c:170(exit_server_common)
Jul 31 08:35:26 h1431219 smbd[14497]: Abnormal server exit: open_sockets_smbd() failed
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.419412, 0] smbd/server_exit.c:171(exit_server_common)
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.510377, 0] lib/util.c:1221(log_stack_trace)
Jul 31 08:35:26 h1431219 smbd[14497]: BACKTRACE: 6 stack frames:
Jul 31 08:35:26 h1431219 smbd[14497]: #0 /usr/sbin/smbd(log_stack_trace+0x1a) [0x7fc57d24cc7a]
Jul 31 08:35:26 h1431219 smbd[14497]: #1 /usr/sbin/smbd(+0x69ecdf) [0x7fc57d4bbcdf]
Jul 31 08:35:26 h1431219 smbd[14497]: #2 /usr/sbin/smbd(+0x69efc1) [0x7fc57d4bbfc1]
Jul 31 08:35:26 h1431219 smbd[14497]: #3 /usr/sbin/smbd(main+0xb85) [0x7fc57cf27575]
Jul 31 08:35:26 h1431219 smbd[14497]: #4 /lib64/libc.so.6(__libc_start_main+0xf5) [0x7fc579d9fa15]
Jul 31 08:35:26 h1431219 smbd[14497]: #5 /usr/sbin/smbd(+0x10ad0d) [0x7fc57cf27d0d]
Jul 31 08:35:26 h1431219 smbd[14497]: [2013/07/31 08:35:26.511167, 0] lib/fault.c:372(dump_core)
Jul 31 08:35:26 h1431219 smbd[14497]: dumping core in /var/log/samba/cores/smbd
Regards
