    CentOS2Alma discussion
  • Please beaware of a breaking change in the REST API on the next Plesk release (18.0.62).
    Starting from Plesk Obsidian 18.0.62, requests to REST API containing the Content-Type header with a media-type directive other than “application/json” will result in the HTTP “415 Unsupported Media Type” client error response code. Read more here
Issue Problem migrating sites
SalvadorS
Regular Pleskian
Debian 12
18.0.58
Hello,
I want to migrate some domains from an old plesk 18.0.27 to a new server with last version of Plesk (18.0.58)
When I start the tool for migrating sites I received this error:
Failed to fetch basic information about resellers, clients and domains data from source servers
Cause: Command execution failed on the local server with non-zero exit code.
command: rsync -r --chmod=Fu=r,Du=rwx,go= --timeout=30 -e 'ssh -i /usr/local/psa/var/modules/panel-migrator/sessions/20240214183340/ssh-keys/id_rsa.x.x.x.x -p xx -o PasswordAuthentication=no -o StrictHostKeyChecking=no -o GSSAPIAuthentication=no' /usr/local/psa/admin/plib/modules/panel-migrator/backend/lib/python/parallels/plesk/source/legacy/extras/plesk_17_0_pmm_shared/ [email protected]:/root/plesk_migrator/plesk_migrator-dopdb34dot6zrtw339h58vx1hqthvqd3/pmm_agent
exit code: 12
stdout:
stderr: [email protected]: Permission denied (publickey,password).
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: error in rsync protocol data stream (code 12) at io.c(231) [sender=3.2.7]
That is a critical error, migration was stopped.
However If I start the migration tool from a Debian 11 server (instead of Debian 12) with the same plesk version 18.0.58 migration tool works perfect.
Any ideas?
Have you set PermitRootLogin to "yes" in /etc/ssh/sshd_config and reloaded the SSH service?
Dear Peter,
Thanks a lot for trying to help me. Yes, I did it. As I told before, I can access from one server (Debian 11) but not with other server (Debian 12) to the "old" plesk server. In the "old" server nothing is changed when I access from one server or another (PermitRootLogin is set to yes)
Also IP restricted access is set to yes in the old server but the IPs of the servers are added correctly.
Are you using "enforcing" mode of SELinux on the source or the target server? In that case you may want to try to "setenforce 0" before the migration to disable it.
Hi again and thanks again for your support
Are you using the latest version of the Plesk Migrator extension?
Yes, If I go to update plesk no updates are pending.
I don´t touch anything from the fresh installation of Debian on the server. I followed this KB article but it does not work:
root@xxx:/XXXs# sestatus | grep "Current mode"
bash: sestatus: orden no encontrada
Thanks a lot.
It's for sure a permission issue, but I cannot determine the root cause from the information given. Please contact Plesk support and let them check it on your server.
To sign-in to support please go to https://support.plesk.com
If you experience login issues, please see this KB article:
https://support.plesk.com/hc/en-us/...rt-plesk-com-and-password-reset-does-not-work
If you bought your license from a reseller, your reseller should provide support for you. If the reseller does not provide support, here is an alternative:
https://support.plesk.com/hc/en-us/articles/12388090147095-How-to-get-support-directly-from-Plesk-
