    CentOS2Alma discussion
  • Inviting everyone to the UX test of a new security feature in the WP Toolkit
    For WordPress site owners, threats posed by hackers are ever-present. Because of this, we are developing a new security feature for the WP Toolkit. If the topic of WordPress website security is relevant to you, we would be grateful if you could share your experience and help us test the usability of this feature. We invite you to join us for a 1-hour online session via Google Meet. Select a convenient meeting time with our friendly UX staff here.
Parallels Panel Mobile Center install problems
Stepster
Basic Pleskian
I'm having problems with the Parallels Panel Mobile Center.
I do have an active Power Pack license, so this should work!
I've installed the Android app and upon connecting to my Plesk Panel, this results in the module being installed on the server. However, it doesn't appear to install correctly.
If I go to 'Extensions' and click on 'Parallels Panel Mobile Center', this is what I see.
Clearly the language pack for the plug-in has not loaded.
Further more, I'm not getting notified of any events on the server. I've had a few incidents of high CPU usage which has triggered email alerts, but no push alerts to my mobile app and these events are not listed on the events page.
I've tried removing the module and re-installing, this does not help.
My '\Parallels\Plesk\var\modules\plesk-mobile' shows the following files present:
config.json
installed-migrations.txt
MobileConnector.log
MobileConnector.sqlite
and 'C:\Program Files (x86)\Parallels\Plesk\var\modules\plesk-mobile'
push_switch.sh
And now, having removed the module and re-installed using the Android app, I'm getting notified of the following event every three minutes or so!
Running task: C:\Program Files (x86)\Parallels\Plesk\admin\bin\php.exe -c "C:\Program Files (x86)\Parallels\Plesk\admin\php.ini" -dauto_prepend_file=sdk.php "C:\Program Files (x86)\Parallels\Plesk\admin\plib\modules\plesk-mobile\scripts\push_worker.php"
Started: Wed Apr 17 11:39:00 2013
Ended successfully: Wed Apr 17 11:40:16 2013
Please can you help?
So, can anyone give me an idea of how to get an acceptable level of support for Plesk Panel?
Having struggled with this problem and watch it cause other knock-on problems with my system, I resorted to purchasing paid support from Parallel. The fairest comment I can give about this is that it's proved useless! It feels like the blind leading the blind!!!
Is there a way to get an acceptable level of support from people that a) Understand the problem, b) Understand the product and c) Might actually be able to resolve the problem?
At the moment, my confidence in Plesk is becoming very very shaky!
Hello, Stepster.
Plesk for Windows always sends notifications about scheduled tasks to administrator email.
To fix annoying notifications use the following KB article: http://kb.parallels.com/116179
I hope push notifications about high CPU usage will be fixed in the next version of mobile app.
