    CentOS2Alma discussion
  • Inviting everyone to the UX test of a new security feature in the WP Toolkit
    For WordPress site owners, threats posed by hackers are ever-present. Because of this, we are developing a new security feature for the WP Toolkit. If the topic of WordPress website security is relevant to you, we would be grateful if you could share your experience and help us test the usability of this feature. We invite you to join us for a 1-hour online session via Google Meet. Select a convenient meeting time with our friendly UX staff here.
Roundcube does not work
please delete the file now for security reasons... as well the attachments containing sensible data.
Follow up in a few minutes..... as an edit to this post
Edit:
Please go to "Tools & Settings > Apache Web Server Settings" and choose your desired modules - but at least the mod_rewrite module.
Deleted the file, there is nog mod_rewrite, i attached a screenshots of the available modules, rewrite module is chosen.
Hi VidjayG,
choose "vhost_alias" "unique_id" "python" "mem_cache" "sysenv" ... the webserver restart should be initiated by Plesk, when you confirm your new setup.
Apart from this I recommend using the commands "apt-get clean && apt-get update && apt-get upgrade", because I get the feeling that there might be updates for your server, waiting to be installed.
Chosen: "vhost_alias" "unique_id" "python" "mem_cache" "sysenv"
Done: "apt-get clean && apt-get update && apt-get upgrade"
Reboot server
webmail.domain.nl still not working
/etc/init.d/psa-firewall stop && iptables -F
o.k... then another way...
/usr/local/psa/admin/bin/autoinstaller --select-product-id plesk --select-release-current --remove-component horde --remove-component roundcube
/usr/local/psa/admin/sbin/httpdmng --reconfigure-all
service apache2 restart && service nginx restart && service php5-fpm restart
mv /usr/share/psa-roundcube /usr/share/psa-roundcube.backup
mv /usr/share/psa-horde /usr/share/psa-horde.backup
/usr/local/psa/admin/bin/autoinstaller --select-product-id plesk --select-release-current --install-component horde --install-component roundcube
Check over the Plesk Control Panel, if the desired Webmail ( Horde or Roundcube ) is used in the domain specific mail settings and tryout as well the other webmail feature. When you changed the webmail feature, Plesk should rewrite the configuration files and restart the webserver automatically. Please try out both features and investigate the depending error - logs like you did earlier after you tried to open the webmail URL with the browser. For Horde you should look as well at the logs in "/var/log/psa-horde/"
... and please switch on the psa-firewall again... the issues doesn't seem to be related to it.​
I migrated the domains on the server to another server. Then reinstalled the server with:
Ubuntu 14.04 LTS 64bit + Plesk 12.0
After this I enabled modules:
I installed BIND through add components
Restarted server
Installed Roundcube through add components
Created a domainentry and created an emailadress with RoundCube as client
Still the same problem exists
In error.log from apache i see:
[ssl:warn] [pid 2703] AH01909: RSA certificate configured for roundcube.webmail:443 does NOT include an ID which matches the server name
After this I did:
/usr/local/psa/admin/bin/autoinstaller --select-product-id plesk --select-release-current --reinstall-patch --install-component base --install-component health-monitor --install-component spamassassin --install-component mod_perl --install-component mod-bw --install-componentmod_python --install-component watchdog
Server reboot
Still not working
var/logs/apache2:
access.log is empty
error.log contains same error as above
/var/log/plesk-roundcube/:
errors is empty
/var/www/vhosts/example.com/logs/ :
access.log is empty
error.log only contains error [Wed Dec 17 01:07:17.808815 2014] [ssl:warn] [pid 2586] AH01909: RSA certificate configured for domain.nl:443 does NOT include an ID which matches the server name
I am really frustrating.....is it an option to give you access?
Could you try this please? And please try as well the option over the Plesk Control Panel to switch between the two webmail - applications in your domain specific mail - settings.
... and again: "[Wed Dec 17 01:07:17.808815 2014] [ssl:warn] [pid 2586] AH01909: RSA certificate configured for domain.nl:443 does NOT include an ID " is not really an error. It is a warning which is caused due to the fact that you use the Plesk standard certificate.
Done
Done
* Restarting web server apache2 AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/plesk.conf.d/server.conf:6
[ OK ]
nginx: unrecognized service
Nginx is not installed at this moment
Done
Done
Tried both Horde and Roundcube through the Plesk interface, same result for both. Page cannot be displayed, webmail.domain.nl not pingable, unknown host
var/log/psa-horde
psa-horde.log: empty
errors: empty
var/log/apache2
access.log: empty, the certificate warnings, nothing about horde/roundcube
just to know, what is the other_vhosts_access.log?
I see information about a site which I moved to another server.
var/log/www/vhosts/domain.nl/logs
access.log: empty
error.log: only messages about certificates
