Application Vault Problem: Connection Error
magic_77
Basic Pleskian
after a server crash i´ve installed a new system with plesk 10.3. Dumped back all mysql stuff and restored all users.
system is running like a charm but with one issue that happened (i didn´t know that before) - so that
application vault runs into trouble.
clicking on "Application Vault" results in
"Internal error: [unixODBC][MySQL][ODBC 3.51 Driver]Access denied for user 'apsc'@'localhost' (using password: YES)"
How to reset the user APSC? or where can i set the password for this user?
can anybody help me out, please
thx
Marek
Hi IgorG,
connecting with "mysql -h 127.0.0.1 -P 3306 -uadmin -p`cat /etc/psa/.psa.shadow`" results in a successful connection.
Because i dumped back the APSC Mysql DB from an other Installation i fear that the passwords doesn´t match.
don´t know what to do.
Greets
Marek
Try to update password for 'apsc' user in 'mysql' database 'users' table.
Hi IgorG,
tried several passwords, still not better. So where does this system stores passwords that are send to mysql to authorize.
passwords i tried are from admin, root
greets marek
IF anyone still need this, I managed to solve the problem. The problem I had was that grants for apsc where set to localhost, however in configuration for Applications host was set to "127.0.0.1" as a result apsc was unable to connect to apsc db. As a solution you need to make update either in GRANTS e.g. set to 127.0.0.1 or set localhost for connections.
steps:
check grants that are set in mysql db and make sure we are going to make correct changes:
[root@ ]#mysql -uadmin -p`cat /etc/psa/.psa.shadow`
mysql> use mysql;
mysql> select * from user where User='apsc';SHOW GRANTS FOR 'apsc'@'localhost';
| Host | User | Password | Select_priv | Insert_priv | Update_priv | Delete_priv | Create_priv | Drop_priv | Reload_priv | Shutdown_priv | Process_priv | File_priv | Grant_priv | References_priv | Index_priv | Alter_priv | Show_db_priv | Super_priv | Create_tmp_table_priv | Lock_tables_priv | Execute_priv | Repl_slave_priv | Repl_client_priv | Create_view_priv | Show_view_priv | Create_routine_priv | Alter_routine_priv | Create_user_priv | Event_priv | Trigger_priv | ssl_type | ssl_cipher | x509_issuer | x509_subject | max_questions | max_updates | max_connections | max_user_connections |
| localhost | apsc | *09C714AAB4B6F7B4704EAC765B6ECBEC26FBF5E9 | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | | | | | 0 | 0 | 0 | 0 |
1 row in set (0.00 sec)
| Grants for apsc@localhost |
| GRANT USAGE ON *.* TO 'apsc'@'localhost' IDENTIFIED BY PASSWORD '*09C714AAB4B6F7B4704EAC765B6ECBEC26FBF5E9' |
| GRANT ALL PRIVILEGES ON `apsc`.* TO 'apsc'@'localhost' |
2 rows in set (0.00 sec)
mysql>
--------->8<----------
As you can see grants are configured to connect from localhost
now we need to check settings that are set in Plesk DB
mysql> use psa;
mysql> select * from misc where param like '%aps%';
| param | val |
| aps_database | apsc |
| aps_host | 127.0.0.1 |
| aps_login | apsc |
| aps_password | <YOU CURRENT PASSWORD>|
| aps_port | 3306 |
5 rows in set (0.00 sec)
mysql>
------->8<-------
as you can see from these lines apsc is trying to connect through 127.0.0.1, so In my case I had to change "127.0.0.1" to "localhost". After this you can confirm if everything is ok by running the following command from shell:
------->8<-------
mysql -hlocalhost -uapsc -p<YOU CURRENT PASSWORD> -P3306 apsc
------->8<-------
P.S. of course it's primitive solution but anyway...
Hi DimitriyH,
hey - many thx for your reply.
My Results for this are:
| Host | User | Password | Select_priv | Insert_priv | Update_priv | Delete_priv | Create_priv | Drop_priv | Reload_priv | Shutdown_priv | Process_priv e_priv | Repl_client_priv | Create_view_priv | Show_view_priv | Create_routine_priv | Alter_routine_priv | Create_user_priv | Event_priv | Trigger_priv | Create_tablespace_priv | ssl_type |
| localhost | apsc | *09C714AAB4B6F7B4704EAC765B6ECBEC26FBF5E9 | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | N | |
mysql> SHOW GRANTS FOR 'apsc'@'localhost';
ERROR 1141 (42000): There is no such grant defined for user 'apsc' on host 'localhost'
Maybe you have an advice - ´cause my sql skill are to low for that
thx
marek
execute the following commands and provide results:
1 - SHOW GRANTS FOR 'apsc'@'127.0.0.1';
2 - select * from misc where param like '%aps%';
in case "1" will not give any results then you will need to add grants manually:
a) GRANT USAGE ON *.* TO 'apsc'@'localhost' IDENTIFIED BY PASSWORD '*09C714AAB4B6F7B4704EAC765B6ECBEC26FBF5E9'
b) GRANT ALL PRIVILEGES ON `apsc`.* TO 'apsc'@'localhost'
P.S. What Plesk version you are using?
ok - doing this:
# REVOKE ALL PRIVILEGES ON *.* FROM 'apsc'@'localhost';
# FLUSH PRIVILEGES;
set´s GRANTS on user. i changed "aps_host" to localhost, but still get an
ERROR 1045 (28000): Access denied for user 'apsc'@'localhost' (using password: YES)
| param | val |
| aps_host | localhost |
| aps_login | apsc |
| aps_password | eK1I4F5X24Va |
| aps_port | 3306 |
this is the result from PSA
and i´m using Plesk 10.31
