L
loopback-martin
We just noticed that the Awstat statistics showed the same info for our Plesk 8.1 test-clients. The statistics included hits from all domains as well.
The solution I found was to add:
export AWSTATS_ENABLE_CONFIG_DIR=1
to the /etc/cron.daily/50plesk.. job, it seems that is needed to force awstats to read the "-configdir " option.
We are running Plesk 8.1 with the latest patches on a Debian 3.1 system. Has anyone else experienced the same problem? Is it a known issue?
/Martin
/Martin
