    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Backups - My Problem
P
Piggie
I am on Plesk 7.5.2 and Virtuozzo
When I do a Manual back up to local repository on any of my name based domains (domains that share the IP of the server) they end up redirected to them main site of the server.
Example. My main IP is 111.111.111.111
and the site there is http://main.com
Then I go back up in plesk a domain called http://anotherone.com on that same IP (shared). After the back up http://anotherone.com when loaded in a browser displays http://main.com
If I do a /usr/local/psa/admin/sbin/websrvmng -a -v
and everything is fine again.
The problem doesn't duplicate on but about 25 to 50% of the back ups.
Which is a real pain and a bug.
It seems domains with their own static IP don't have this problem.
Any one have an idea?
I am stating a second problem in a separate post so they are not confused.
The other problem is no matter when I tell Plesk to do a scheduled back up it does
it at 04:30
And they are not full backups. They are in 40 to 60K range on sites that are 100M.
Maybe Plesk backup doesn't work at all?
Should I head to 4PSA and spend money on something swsoft doesn't seem to be able to fix?
Ideas?
