Hello,
Since upgrading to 12.0.18 Update # 5 fail2ban stopped working.
I did several tests but have not found the issue!
I did not understand how works "fail2ban" with plesk 12, usually in the file jail.conf there are default options and the list of jails.
jail.conf after the upgrade is as follows:
plesk uses different conf file? where are other jail settings?
I also found jail.conf but it seems incomplete....
this is the log file after "service fail2ban start"
I thought it would be a mistake to regex, but the check was successful
even if the regex is correct fail2ban "fails to ban":
What do you think? any suggestion is appreciated!
Regards
Code:
[nimda4597@xxxx fail2ban]# service fail2ban status
fail2ban-server (pid 1881) is running...
Status
|- Number of jail: 8
`- Jail list: recidive, plesk-roundcube, plesk-panel, plesk-courierimap, ssh, plesk-postfix, plesk-horde, plesk-proftpd
Code:
# If pyinotify is not installed, Fail2ban will use auto.
# gamin: requires Gamin (a file alteration monitor) to be installed.
# If Gamin is not installed, Fail2ban will use auto.
# polling: uses a polling algorithm which does not require external libraries.
# auto: will try to use the following backends, in order:
# pyinotify, gamin, polling.
backend = auto
# "usedns" specifies if jails should trust hostnames in logs,
# warn when DNS lookups are performed, or ignore all hostnames in logs
# yes: if a hostname is encountered, a DNS lookup will be performed.
# warn: if a hostname is encountered, a DNS lookup will be performed,
# but it will be logged as a warning.
# no: if a hostname is encountered, will not be used for banning,
# but it will be logged as info.
usedns = no
# This jail corresponds to the standard configuration in Fail2ban.
# The mail-whois action send a notification e-mail with a whois request
# in the body.
[ssh]
enabled = false
filter = sshd
action = iptables[name=SSH, port=ssh, protocol=tcp]
logpath = /var/log/secure
maxretry = 5
# Jail for more extended banning of persistent abusers
# !!! WARNING !!!
# Make sure that your loglevel specified in fail2ban.conf/.local
# is not at DEBUG level -- which might then cause fail2ban to fall into
# an infinite loop constantly feeding itself with non-informative lines
[recidive]
enabled = false
filter = recidive
logpath = /var/log/fail2ban.log
action = iptables-allports[name=recidive]
bantime = 604800 ; 1 week
findtime = 86400 ; 1 day
maxretry = 5
Code:
[DEFAULT]
maxretry = 3
destemail = xxx@xxxx
findtime = 600
bantime = 600
[plesk-apache-badbot]
enabled = false
[recidive]
enabled = true
[plesk-roundcube]
enabled = true
[plesk-panel]
enabled = true
[plesk-apache]
enabled = false
[plesk-courierimap]
enabled = true
[ssh]
enabled = true
[plesk-postfix]
enabled = true
[plesk-horde]
enabled = true
[plesk-proftpd]
enabled = true
Code:
2014-07-01 02:42:39,492 fail2ban.server [3244]: INFO Changed logging target to /var/log/fail2ban.log for Fail2ban v0.8.13
2014-07-01 02:42:39,493 fail2ban.jail [3244]: INFO Creating new jail 'recidive'
2014-07-01 02:42:39,512 fail2ban.jail [3244]: INFO Jail 'recidive' uses pyinotify
2014-07-01 02:42:39,523 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,524 fail2ban.filter [3244]: INFO Added logfile = /var/log/fail2ban.log
2014-07-01 02:42:39,524 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,525 fail2ban.filter [3244]: INFO Set findtime = 86400
2014-07-01 02:42:39,525 fail2ban.actions[3244]: INFO Set banTime = 604800
2014-07-01 02:42:39,531 fail2ban.jail [3244]: INFO Creating new jail 'plesk-roundcube'
2014-07-01 02:42:39,531 fail2ban.jail [3244]: INFO Jail 'plesk-roundcube' uses pyinotify
2014-07-01 02:42:39,531 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,532 fail2ban.filter [3244]: INFO Added logfile = /var/log/plesk-roundcube/errors
2014-07-01 02:42:39,532 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,533 fail2ban.filter [3244]: INFO Set findtime = 600
2014-07-01 02:42:39,533 fail2ban.actions[3244]: INFO Set banTime = 600
2014-07-01 02:42:39,537 fail2ban.jail [3244]: INFO Creating new jail 'plesk-courierimap'
2014-07-01 02:42:39,537 fail2ban.jail [3244]: INFO Jail 'plesk-courierimap' uses pyinotify
2014-07-01 02:42:39,537 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,538 fail2ban.filter [3244]: INFO Added logfile = /var/log/maillog
2014-07-01 02:42:39,538 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,539 fail2ban.filter [3244]: INFO Set findtime = 600
2014-07-01 02:42:39,539 fail2ban.actions[3244]: INFO Set banTime = 600
2014-07-01 02:42:39,545 fail2ban.jail [3244]: INFO Creating new jail 'ssh'
2014-07-01 02:42:39,545 fail2ban.jail [3244]: INFO Jail 'ssh' uses pyinotify
2014-07-01 02:42:39,546 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,546 fail2ban.filter [3244]: INFO Added logfile = /var/log/secure
2014-07-01 02:42:39,547 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,547 fail2ban.filter [3244]: INFO Set findtime = 600
2014-07-01 02:42:39,548 fail2ban.actions[3244]: INFO Set banTime = 600
2014-07-01 02:42:39,670 fail2ban.jail [3244]: INFO Creating new jail 'plesk-postfix'
2014-07-01 02:42:39,670 fail2ban.jail [3244]: INFO Jail 'plesk-postfix' uses pyinotify
2014-07-01 02:42:39,670 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,671 fail2ban.filter [3244]: INFO Added logfile = /var/log/maillog
2014-07-01 02:42:39,671 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,672 fail2ban.filter [3244]: INFO Set findtime = 600
2014-07-01 02:42:39,672 fail2ban.actions[3244]: INFO Set banTime = 600
2014-07-01 02:42:39,678 fail2ban.jail [3244]: INFO Creating new jail 'plesk-panel'
2014-07-01 02:42:39,678 fail2ban.jail [3244]: INFO Jail 'plesk-panel' uses pyinotify
2014-07-01 02:42:39,678 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,679 fail2ban.filter [3244]: INFO Added logfile = /var/log/plesk/panel.log
2014-07-01 02:42:39,679 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,680 fail2ban.filter [3244]: INFO Set findtime = 600
2014-07-01 02:42:39,680 fail2ban.actions[3244]: INFO Set banTime = 600
2014-07-01 02:42:39,684 fail2ban.jail [3244]: INFO Creating new jail 'plesk-horde'
2014-07-01 02:42:39,684 fail2ban.jail [3244]: INFO Jail 'plesk-horde' uses pyinotify
2014-07-01 02:42:39,684 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,685 fail2ban.filter [3244]: INFO Added logfile = /var/log/psa-horde/psa-horde.log
2014-07-01 02:42:39,685 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,686 fail2ban.filter [3244]: INFO Set findtime = 600
2014-07-01 02:42:39,686 fail2ban.actions[3244]: INFO Set banTime = 600
2014-07-01 02:42:39,690 fail2ban.jail [3244]: INFO Creating new jail 'plesk-proftpd'
2014-07-01 02:42:39,690 fail2ban.jail [3244]: INFO Jail 'plesk-proftpd' uses pyinotify
2014-07-01 02:42:39,690 fail2ban.jail [3244]: INFO Initiated 'pyinotify' backend
2014-07-01 02:42:39,691 fail2ban.filter [3244]: INFO Added logfile = /var/log/secure
2014-07-01 02:42:39,692 fail2ban.filter [3244]: INFO Set maxRetry = 5
2014-07-01 02:42:39,692 fail2ban.filter [3244]: INFO Set findtime = 600
2014-07-01 02:42:39,692 fail2ban.actions[3244]: INFO Set banTime = 600
2014-07-01 02:42:39,713 fail2ban.jail [3244]: INFO Jail 'recidive' started
2014-07-01 02:42:39,715 fail2ban.jail [3244]: INFO Jail 'plesk-roundcube' started
2014-07-01 02:42:39,727 fail2ban.jail [3244]: INFO Jail 'plesk-courierimap' started
2014-07-01 02:42:39,733 fail2ban.jail [3244]: INFO Jail 'ssh' started
2014-07-01 02:42:39,734 fail2ban.jail [3244]: INFO Jail 'plesk-postfix' started
2014-07-01 02:42:39,736 fail2ban.jail [3244]: INFO Jail 'plesk-panel' started
2014-07-01 02:42:39,737 fail2ban.jail [3244]: INFO Jail 'plesk-horde' started
2014-07-01 02:42:39,739 fail2ban.jail [3244]: INFO Jail 'plesk-proftpd' started
Code:
[nimda4597@xxxx fail2ban]# fail2ban-regex /var/log/maillog /etc/fail2ban/filter.d/postfix-sasl.conf
Running tests
Use failregex file : /etc/fail2ban/filter.d/postfix-sasl.conf
Use log file : /var/log/maillog
Results
Failregex: 4293 total
|- #) [# of hits] regular expression
| 1) [4293] ^\s*(<[^.]+\.[^.]+>)?\s*(?:\S+ )?(?:kernel: \[ *\d+\.\d+\] )?(?:@vserver_\S+ )?(?:(?:\[\d+\])?:\s+[\[\(]?postfix/smtpd(?:\(\S+\))?[\]\)]?:?|[\[\(]?postfix/smtpd(?:\(\S+\))?[\]\)]?:?(?:\[\d+\])?:?)?\s(?:\[ID \d+ \S+\])?\s*warning: [-._\w]+\[<HOST>\]: SASL (?:LOGIN|PLAIN|(?:CRAM|DIGEST)-MD5) authentication failed(: [ A-Za-z0-9+/]*={0,2})?\s*$
Ignoreregex: 0 total
Date template hits:
|- [# of hits] date format
| [248025] MONTH Day Hour:Minute:Second
Lines: 248025 lines, 0 ignored, 4293 matched, 243732 missed
Missed line(s): too many to print. Use --print-all-missed to print all 243732 lines
Code:
[[nimda4597@xxxx fail2ban]# fail2ban-client status plesk-postfix
Status for the jail: plesk-postfix
|- filter
| |- File list: /var/log/maillog
| |- Currently failed: 0
| `- Total failed: 0
`- action
|- Currently banned: 0
| `- IP list:
`- Total banned: 0
Regards
