JogoVogo
Basic Pleskian
Hi together,
i have a big problem with fail2ban...
if i start the fail2ban services the syslog put out this non stop:
ERROR findFailure failed to parse timeText: Jan 26 07:17:40 1582
When it found something:
postfix/smtpd[10402]: warning: 110-170-169-86.static.asianet.co.th[110.170.169.86]: SASL LOGIN authentication failed: authentication failure' but no valid date/time found for u'Jan 26 16:18:19 1582'. Please try setting a custom date pattern (see man page jail.conf(5)). If format is complex, please file a detailed issue on https://github.com/fail2ban/fail2ban/issues in order to get support for this format.
Also the menu item in Plesk stopp working after start/restart fail2ban.
The funny thing it worked without any error when no "jail" is activated .
fail2ban.server[21146]: INFO Changed logging target to SYSLOG (/dev/log) for Fail2ban v0.9.3
fail2ban.database[21146]: INFO Connected to fail2ban persistent database '/var/lib/fail2ban/fail2ban.sqlite3'
The version:
fail2ban-0.9.3-1.el6.1.noarch
on
OS CentOS 6.7 (Final)
Plesk Version 12.0.18 Update #75
Do i need special timepattern?
I have no idea what I can do about it..., please help ;-))
regards
ron
The version:
on
regards
ron
