SMAHI
Basic Pleskian
Hello,
I am not able to access Plesk panel any more, i am getting BAD GATEWAY 502.
I've checked the running process and see the following error
Please help
Code:
● sw-engine.service - Startup script for Panel sw-engine
Loaded: loaded (/usr/lib/systemd/system/sw-engine.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2017-02-07 09:50:15 CET; 39s ago
Process: 1289 ExecStopPost=/usr/bin/find /run/lock/lmlib/ -mindepth 1 -delete (code=exited, status=0/SUCCESS)
Process: 916 ExecStart=/usr/sbin/sw-engine-fpm --fpm-config /etc/sw-engine/sw-engine-fpm.conf -c /usr/local/psa/admin/conf/php.ini --nodaemonize --pid /run/sw-engine.pid (code=exited, status=127)
Main PID: 916 (code=exited, status=127)
Feb 07 09:50:14 vmi98940.contabo.host systemd[1]: Starting Startup script for Panel sw-engine...
Feb 07 09:50:15 vmi98940.contabo.host sw-engine-fpm[916]: /usr/sbin/sw-engine-fpm: error while loading shared libraries: liblog4cplus-1.1.so.9: c...rectory
Feb 07 09:50:15 vmi98940.contabo.host systemd[1]: sw-engine.service: main process exited, code=exited, status=127/n/a
Feb 07 09:50:15 vmi98940.contabo.host systemd[1]: Failed to start Startup script for Panel sw-engine.
Feb 07 09:50:15 vmi98940.contabo.host systemd[1]: Unit sw-engine.service entered failed state.
Feb 07 09:50:15 vmi98940.contabo.host systemd[1]: sw-engine.service failed.
Please help
