C
Chris
I have a new Plesk 7.5.3 server running on CentOS 3.3. I set up a domain for SSL (I have been using Plesk for quite some time and I'm very certain I set this up correctly). The domain works correctly via http; however, when I go to https://www.domain.com I get a "Cannot find server" error.
When I restart Apache I'm getting this error:
NameVirtualHost xxx.xxx.xxx.xxx:443 has no VirtualHosts
(The xxx's are IP addresses of course.) It repeats the same message for all of the IPs on the server. Apache starts okay, but no https. I looked in the httpd error_log and nothing there to indicate the problem.
I should mention that the Plesk control panel is working fine, so I assume SSL is running on the server okay.
I did a search here and found a couple of threads that talk about this exact problem but no solutions. I hope someone can help.
