JSP MySql Connectivity Problem
B
buntyindia
I Am getting Socket error while using this code whereas this code is working fine on my localTomcat Server.
Code:
<%@ page import = "java.io.*, java.util.*,java.net.URL,java.awt.*,java.lang.*,java.sql.*" %>
<%@ page import="com.mysql.jdbc.Driver" %>
<HTML>
<head></head>
<body>
    ResultSet rs;
	Statement stmt;
     try {
          Class.forName("com.mysql.jdbc.Driver").newInstance();
Connection conn = DriverManager.getConnection("jdbc:mysql://localhost/petrofe","petro", "petro");
	String sql = "SELECT * FROM sample";
	stmt = conn.createStatement();
	rs = stmt.executeQuery(sql);
	while (rs.next())
		out.println(rs.getString(1));
		out.println(rs.getString(2));
             // Do something with the Connection
         } catch (SQLException ex) {
             // handle any errors
             out.println("SQLException: " + ex.getMessage());
             out.println("SQLState: " + ex.getSQLState());
             out.println("VendorError: " + ex.getErrorCode());
         catch (ClassNotFoundException cnfex)
		 	       out.println("SQLException: " + cnfex.getMessage());
</body>
</html>
ERROR
SQLException: Communications link failure due to underlying exception: ** BEGIN NESTED EXCEPTION ** java.security.AccessControlException MESSAGE: access denied (java.net.SocketPermission localhost resolve) STACKTRACE: java.security.AccessControlException: access denied (java.net.SocketPermission localhost resolve) at java.security.AccessControlContext.checkPermission(AccessControlContext.java:269) at java.security.AccessController.checkPermission(AccessController.java:401) at java.lang.SecurityManager.checkPermission(SecurityManager.java:524) at java.lang.SecurityManager.checkConnect(SecurityManager.java:1023) at java.net.InetAddress.getAllByName0(InetAddress.java:1000) at java.net.InetAddress.getAllByName0(InetAddress.java:981) at java.net.InetAddress.getAllByName(InetAddress.java:975) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:133) at com.mysql.jdbc.MysqlIO.(MysqlIO.java:281) at com.mysql.jdbc.Connection.createNewIO(Connection.java:1696) at com.mysql.jdbc.Connection.(Connection.java:408) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:270) at java.sql.DriverManager.getConnection(DriverManager.java:512) at java.sql.DriverManager.getConnection(DriverManager.java:171) at org.apache.jsp.mysqldb2_jsp._jspService(mysqldb2_jsp.java:62) at org.apache.jasper.runtime.HttpJspBase.service(Unknown Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java) at org.apache.jasper.servlet.JspServletWrapper.service(Unknown Source) at org.apache.jasper.servlet.JspServlet.serviceJspFile(Unknown Source) at org.apache.jasper.servlet.JspServlet.service(Unknown Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Unknown Source) at org.apache.catalina.core.ApplicationFilterChain.access$0(Unknown Source) at org.apache.catalina.core.ApplicationFilterChain$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at org.apache.catalina.core.ApplicationFilterChain.doFilter(Unknown Source) at org.apache.catalina.core.StandardWrapperValve.invoke(Unknown Source) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(Unknown Source) at org.apache.catalina.core.StandardPipeline.invoke(Unknown Source) at org.apache.catalina.core.ContainerBase.invoke(Unknown Source) at org.apache.catalina.core.StandardContextValve.invoke(Unknown Source) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(Unknown Source) at org.apache.catalina.core.StandardPipeline.invoke(Unknown Source) at org.apache.catalina.core.ContainerBase.invoke(Unknown Source) at org.apache.catalina.core.StandardContext.invoke(Unknown Source) at org.apache.catalina.core.StandardHostValve.invoke(Unknown Source) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(Unknown Source) at org.apache.catalina.valves.ErrorDispatcherValve.invoke(Unknown Source) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(Unknown Source) at org.apache.catalina.valves.ErrorReportValve.invoke(Unknown Source) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(Unknown Source) at org.apache.catalina.core.StandardPipeline.invoke(Unknown Source) at org.apache.catalina.core.ContainerBase.invoke(Unknown Source) at org.apache.catalina.core.StandardEngineValve.invoke(Unknown Source) at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(Unknown Source) at org.apache.catalina.core.StandardPipeline.invoke(Unknown Source) at org.apache.catalina.core.ContainerBase.invoke(Unknown Source) at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:223) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:594) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:392) at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:565) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:619) at java.lang.Thread.run(Thread.java:534) ** END NESTED EXCEPTION ** SQLState: 08S01 VendorError: 0
Please Help
Bunty
I am not a java programmer at all, but it appears that your getting a permission error. I would begin by making certain that your user/pass for mysql are working. Type the following from the command line:
mysql -u petro -p
You should be prompted for your password, if you get a successfull connection: mysql>
you will have at least narrowed the problem down to a tomcat/jdbc problem, and not a mysql problem.
If that doesn't work, hopefully someone with more java experience would be able to help.
In /var/tomcat4/conf/catalina.policy
add the following to the web application grant section
permission java.net.SocketPermission "localhost:3306", "connect,resolve";
Bill
