O
Otakucouk
I am attempting to achieve PCI compliance on a Windows VPS running Plesk 9.2.3. I have turned off the Plesk website and blocked port 8443 in the firewall, but two failures are still occurring. It appears that the Plesk login screen (https://www.otaku.co.uk:8443) is still able to respond somehow. Is there any way of stopping it?
The failures are:
Protocol Port Program Risk Summary
TCP 8443 pcsync-https 5 Synopsis : This web server leaks a private IP address through its HTTP headers. Description : This may expose internal IP addresses that are usually hidden or masked behind a Network Address Translation (NAT) Firewall or proxy server. There is a known issue with Microsoft IIS 4.0 doing this in its default configuration. This may also affect other web servers, web applications, web proxies, load balancers and through a variety of misconfigurations related to redirection. See also : http://support.microsoft.com/support/kb/ articles/Q218/1/80.ASP See the Bugtraq reference for a full discussion. Solution: None Risk Factor: Medium / CVSS Base Score : 5.0 (CVSS2#AV:N/AC:L/Au:N/C/I:N/A:N) CVE : CVE-2000-0649 BID : 1499 Other references : OSVDB:630
TCP 8443 pcsync-https 4 Synopsis : The remote service encrypts traffic using a protocol with known weaknesses. Description : The remote service accepts connections encrypted using SSL 2.0, which reportedly suffers from several cryptographic flaws and has been deprecated for several years. An attacker may be able to exploit these issues to conduct man-in-the-middle attacks or decrypt communications between the affected service and clients. See also : http://www.schneier.com/paper-ssl.pdf Solution: Consult the application's documentation to disable SSL 2.0 and use SSL 3.0 or TLS 1.0 instead. Risk Factor: Medium / CVSS Base Score : 2 (AV:R/AC:L/Au:NR/C/A:N/I:N/B:N)
The failures are:
