Please help with locale problem
V
vadims
Any help is appreciated as I run out of ideas.
I'm running a website with classic asp and ms access. On my local web server when I insert a date it is displayed correctly having dd/mm/yyyy format but when I run it form my vps hosting account (running Plesk 8.6) the date part is switched with the month part and gives mm/dd/yyyy format when the date part is less than '12'. I have set the correct session.LCID but it has no affect on the way that dates are formatted.
Does virtual containers support multiple locale settings? If so, how am I going to enable the correct one to give me the proper locale formats and numbers?
Thank you
