plesk Firewall module problem
A
atomicmak
i am trying to use plesk's firewall module and i defined some policy which shows
/etc/rc.d/init.d/iptables status
but after 5 to 10 minutes it gets clear up if i issue same command it shows nothing in filter chain
here is sample :
[root@ns3 root]# /etc/rc.d/init.d/iptables status
Table: filter
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Table: mangle
Chain PREROUTING (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
Table: nat
[root@ns3 root]#
i have problem because i am blocking
china, korea, russia, and many more network due to spam and other attacks coming to my server and my customer has no reach in this countries and no need from this customers specially for spam mails.
the problem is iptables not working properly and so i cant get it work.
i did try to save iptables and added some more rule by hand through VI command and when i restart iptables it start working again but then in another 5 minutes its status shows blank chain.
Can any one help me to solve this problem ?
i am so much tired setting up it again and again and i cant go to ssh and restart it every 5 minutes.
please help.
i just found that there was apf installed along with bfd
Dec 05 17:25:00 ns3 apf(6304): flushing & zeroing chain policies
Dec 05 17:25:00 ns3 apf(6304): firewall offline
Dec 05 17:30:00 ns3 apf(9615): flushing & zeroing chain policies
Dec 05 17:30:00 ns3 apf(9615): firewall offline
Dec 05 17:35:01 ns3 apf(13060): flushing & zeroing chain policies
Dec 05 17:35:01 ns3 apf(13060): firewall offline
Dec 05 17:40:01 ns3 apf(16044): flushing & zeroing chain policies
Dec 05 17:40:01 ns3 apf(16044): firewall offline
can any one tell me how to resolve ?
Plesk Firewall module error
I try to add a firewall rule to block IP addresses.
I get an error when I activate the rule.
Error: Could not activate firewall configuration:
safeact: safeact: /usr/local/psa/var/modules/firewall/firewall-new.sh failed:
iptables: No chain/target/match by that name
proc_close() failed: var: Deprecated. Please use the public/private/protected modifiers
Running Plesk 8.1, FC5 x86 64-bit. Think there is a old script that does work in the new version Plesk/OS env.
Any can help?
Or is Plesk development team going to provide this urgent bug fix? Crucial for security!
Thanks.
D'HUB
