• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • Support for BIND DNS has been removed from Plesk for Windows due to security and maintenance risks.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
Plesk is using correct SSL cert; site is stuck with deleted default cert???
G
grimbergen
I've installed the SSL cert in the main server, and it went in without errors.
Then i checked the box next to the cert and clicked "setup", which caused Plesk to restart with the new SSL cert.
I then deleted the original default cert, and then I stopped/started apache.
I went back to the domain I created to verify that the it had picked up the new cert in the setup page of that domain.
However, the domain site is still using the default cert that is deleted! Plesk (accessed via IP), however, is now using the new, correct cert.
How can this be? Did I miss a step? thanks
