PMM is ending with the error "Content will not be copied due to source and destination point to the same directory". Why is this?
Source server is Plesk 8, Dest server is Plesk 11. Using PMM supplied with Plesk 11.
12:30:19|INFO: 4632.log pmm-ras finished. Exit cod 0
2013-05-21T13:02:48-07:00 INFO (6): backup_Converter_Panel10::_convertCommand started from \temp\20130521125618268\PleskDump\converted_info_1305211302.xml to \temp\20130521125618268\PleskDump
2013-05-21T13:02:48-07:00 INFO (6): Dump version is 9.0
2013-05-21T13:02:48-07:00 DEBUG (7): Applying transformation \Program Files (x86)\Parallels\Plesk\admin\plib\backup\Converter\Panel10.xslt
2013-05-21T13:02:48-07:00 DEBUG (7): Applying transformation \Program Files (x86)\Parallels\Plesk\admin\plib\backup\Converter\Panel102.xslt
2013-05-21T13:02:48-07:00 DEBUG (7): Applying transformation \Program Files (x86)\Parallels\Plesk\admin\plib\backup\Converter\Panel103.xslt
2013-05-21T13:02:48-07:00 DEBUG (7): Applying transformation \Program Files (x86)\Parallels\Plesk\admin\plib\backup\Converter\Panel104.xslt
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default limits for domain xxxxxxxxxxxxxxxxxxxxxxxxxxx.com
2013-05-21T13:02:48-07:00 DEBUG (7): Limit disk_space was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_box was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_db was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_dom_aliases was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_fpse_users was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_maillists was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_mssql_db was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_odbc was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_shared_ssl_links was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_subdom was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_subftp_users was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_traffic was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_webapps was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit max_wu was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit mbox_quota was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit mssql_dbase_space was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit mysql_dbase_space was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit total_mbox_quota was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Limit overuse was found in dump
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for total_mboxes_quota
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for max_cf_dsn
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for expiration
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for create_domains
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_phosting
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_php_settings
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_performance
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_sh_access
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_quota
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_subdomains
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_domain_aliases
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_log
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_anonftp
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_subftp
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_crontab
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_dns
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_webapps
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_mail_settings
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_maillists
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_spamfilter
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_virusfilter
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_iis_app_pool
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_webstat
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_additional_permissions
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_shared_ssl
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for select_db_server
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for allow_local_backups
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for allow_ftp_backups
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for access_appcatalog
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for allow_insecure_sites
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_website_maintenance
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for manage_protected_dirs
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for access_service_users
2013-05-21T13:02:48-07:00 DEBUG (7): Fix default value for allow_license_stubs
2013-05-21T13:02:48-07:00 DEBUG (7): Content will not be copied due to source and destination point to the same directory
2013-05-21T13:02:48-07:00 INFO (6): Only main XML file will be converted
2013-05-21T13:02:48-07:00 INFO (6): backup_Converter_Panel10::_convertCommand finished
13:02:54|INFO: 2532.log pmm-ras started : "\Program Files (x86)\Parallels\Plesk\admin\bin\pmm-ras" --convert-local-dump "--dump-storage=\temp\20130521125618268\PleskDump\\" "--dump-specification=converted_info_1305211302.xml.withowners" "--session-path=\Program Files (x86)\Parallels\Plesk\PMM\logs"
13:02:54|INFO: 2532.log Repository '/temp/20130521125618268/PleskDump/' initialising...
13:02:54|INFO: 2532.log Repository '/temp/20130521125618268/PleskDump/': Initialized
13:02:54|INFO: 2532.log Repository '/temp/20130521125618268/PleskDump/': Convert local backup to current Panel version converted_info_1305211302.xml.withowners
13:02:54|INFO: 2532.log Executing utility: "/Program Files (x86)/Parallels/Plesk/admin/bin/pre10-backup-convert" --can-convert -source /temp/20130521125618268/PleskDump/converted_info_1305211302.xml.withowners
2013-05-21T13:02:57-07:00 INFO (6): backup_Converter_Panel10::_canConvertCommand started from /temp/20130521125618268/PleskDump/converted_info_1305211302.xml.withowners
2013-05-21T13:02:57-07:00 INFO (6): Dump version is 10.4
2013-05-21T13:02:57-07:00 INFO (6): backup_Converter_Panel10::_canConvertCommand finished
13:02:57|INFO: 2532.log The utility succesfully executed.
13:02:57|INFO: 2532.log The return code was
The output on STDOUT was:
false
No output on STDERR were performed by the utility
13:02:57|INFO: 2532.log pmm-ras finished. Exit cod 0
false
