Power Tools Professional Add-on for Plesk
danami
Silver Pleskian
Save time and money with Power Tools Pro for Plesk! These tools were written as a result of working with Plesk for over 10 years. Many times the system administrator needs to lookup information for many domains or perform repetitive tasks. These tools leverage the data stored in the Plesk database and put it in the hands of the system administrator. Gone are the days of manually running complex SQL queries to try and get at the data!
Link
http://www.danami.com/products/plesk-extensions/power-tools-professional
Network Information
- Perform bulk DNS, Whois Geo, ASN, Ping, Trace, SPF, and DNSBL and Map lookups.
- Supports internationalized domain names.
- Enter your own query or choose from a select list of your servers domains and IP addresses.
- Add your own DNS servers or randomize nameservers.
- Map lookups use new Maxmind database format fully supporting IPv6.
- Automatically update the Maxmind database at specified intervals.
DNS Blacklist Check
- Check your servers IP addresses against multiple RBLs.
- Schedule a nightly check and receive an email alert if any of your IP addresses gets blacklisted.
- Supports checking your domains against SURBLs (SURBLs are lists of web sites that have appeared in unsolicited messages).
- Bulk IP address selector allows you to check multiple IP addresses at a time.
- Supports all the major RBLs: zen.spamhaus.org, bl.spamcop.net, b.barracudacentral.org, bl.score.senderscore.com etc.
- Add your own third party DNS blacklists.
Password Recovery
- Lookup email, system (FTP), database, and web user passwords.
- Transparently decrypts passwords when using Plesks "Security Enhanced Mode".
- Restrict password lookups from certain IP addresses or CIDRs only.
- Specify what types of passwords staff are allowed to lookup.
- Blacklist certain domains from being able to lookup their passwords.
- All password lookups are logged in the action log.
- Easily copy passwords to your clipboard.
DNS Difference Check
- Lookup A, AAAA, MX and NS database records and compare them against an external DNS server.
- Choose between Google Public DNS, Open DNS, or OpenNIC servers.
- Difference report highlights changes in red and additions in green.
- Bulk domain selector allows you to lookup many domains at a time.
- Easily spot DNS problems including if a domain has expired.
- Shows you the hosting type, DNS and mail service status for each domain.
Email Address Creator
- Create and make changes to email addresses in bulk.
- Supports mailbox options like mailbox enabled, access to control panel, mange spam and virus filters, and mailbox quota.
- Provide your own mailbox passwords on creation or let the tool generate them for you.
- Email password strength is automatically determined from your current Plesk security level or you can override it.
- Passwords are passed securely command line tools via the PSA_PASSWORD environment variable.
Statistics and Reporting
- Over 15 pre-build reports included and more are being written.
- Export report data to CSV file so you can import into a spreadsheet.
- Reports are as simple a providing a SQL query and outputting to a table class.
- Write your own reports using any data stored in the Plesk database.
- Full source code is provided for all report plugins so you can them as examples.
Current Version
powertools-1.10-20160806
Supported Operating Systems
Centos 7.x, CentOS 6.x, CentOS 5.x, Cloudlinux 7.x, CloudLinux 6.x, CloudLinux 5.x, Debian 8.0, Debian 7.0, Debian 6.0, RedHat Enterprise Linux 7.x, RedHat Enterprise Linux 6.x, RedHat Enterprise Linux 5.x, Ubuntu 14.04, Ubuntu 12.04, Ubuntu 10.04
Supported VPS
Virtuozzo, OpenVZ, KVM, Xen, Vmware
Supported Plesk Versions
Plesk 12.x, Plesk 11.x
