• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Problem to have postfix/courier work with two domains (separate ip addresses)
Hans Huckebein
I'm running Debian 7.5 (wheezy) and have 2 domains connected.
I managed to get postfix/courier to work with dedicated ssl certificate for one domain but not for both.
What I did as far as Courier is concerned
Replace the pop3d.pem/imapd.pem (both having the private key/certificate/ca certificate/bundle certificate) all from Thawte with the corresponding pop3d/imapd files but adding the ip addresses in the form
pop3d.pem.x.x.x.x /imapd.pem.x.x.x.x respectively.
The files are located in /usr/share
Postfix
added under /etc/postfix a new directory named keys and copied
the domain1.private.key domain1.cert.pem domain2.private.key domain2.cert.pem files into that directory
For postfix main.cf
- commented out
# smtpd_tls_cert_file = /etc/postfix/domain1.pem
# smtpd_tls_key_file = $smtpd_tls_cert_file
For postfix master.cf
- added/modified
smtp inet n - - - - smtpd
-o smtpd_proxy_filter=127.0.0.1:10024
-o content_filter=dksign:127.0.0.1:10027
-o smtpd_client_connection_count_limit=100
submission inet n - - - - smtpd
-o smtpd_enforce_tls=yes
-o smtpd_etrn_restrictions=reject
-o smtpd_sasl_auth_enable=yes
-o content_filter=dksign:[127.0.0.1]:10027
-o receive_override_options=no_address_mappings
-o smtpd_recipient_restrictions=permit_mynetworks,permit_sasl_authenticated,reject
smtps inet n - - - - smtpd
-o smtpd_tls_wrappermode=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
# localhost
127.0.0.1:smtp inet n - y - 20 smtpd
-o smtpd_tls_key_file=/etc/postfix/keys/mail.example.com.key
-o smtpd_tls_cert_file=/etc/postfix/keys/mail.example.com.crt
127.0.0.1:smtps inet n - y - - smtpd
127.0.0.1:submission inet n - y - - smtpd
# www.domain1.de with ip xx.xx.xx.xx
xx.xx.xx.xx:smtp inet n - y - 20 smtpd
-o smtpd_tls_key_file=/etc/postfix/keys/domain1.de.key
-o smtpd_tls_cert_file=/etc/postfix/keys/domain1.cert.pem
xx.xx.xx.xx:smtps inet n - y - - smtpd
xx.xx.xx.xx:submission inet n - y - - smtpd
# domain2 with ip yy.yy.yy.yy
yy.yy.yy.yy:smtp inet n - y - 20 smtpd
-o smtpd_tls_key_file=/etc/postfix/keys/domain2.de.key
-o smtpd_tls_cert_file=/etc/postfix/keys/domain2.cert.pem
yy.yy.yy.yy:smtps inet n - y - - smtpd
yy.yy.yy.yy:submission inet n - y - - smtpd
After restarting the services I got an error for the line
As I am not an expert at all (got the config from http://blog.wpkg.org/2013/07/31/postfix-and-multiple-ssl-certificates/) I don't know where to look for the problem.
