    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Problem using Contenido CMS
P
PixXel
i have problems to use my CMS (Contenido: http://www.contenido.org/en/index-d-205-4.html)
I will install the Backend for all Customers on cms.mydomain.de.
The Frontends should reside at their own httpdocs.
The folders after install on cms.mydomain.de:
D:\Inetpub\vhosts\cms.mydomain.de\httpdocs\cms <- Fontend 1. Customer
D:\Inetpub\vhosts\cms.mydomain.de\httpdocs\conlib
D:\Inetpub\vhosts\cms.mydomain.de\httpdocs\contenido <- Backend
D:\Inetpub\vhosts\cms.mydomain.de\httpdocs\docs
D:\Inetpub\vhosts\cms.mydomain.de\httpdocs\pear
D:\Inetpub\vhosts\cms.mydomain.de\httpdocs\setup <- delete after setup
If i create a new customer (example cms2), the frontend will be created in
D:\Inetpub\vhosts\cms.mydomain.de\httpdocs\cms2
But I want to create the frontend in the customers httpdocs
D:\Inetpub\vhosts\cms2.de\httpdocs
In Contenido I can easy edit the Pathes, but how to change the permissions for edit files over the Backend?
Does anyone knows how to get this working?
