• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
Problem with domain having digits in first
ThanhN
Basic Pleskian
Panel version 10.4.4 Update #21, last updated at Mar 9, 2012 01:25 AM
Please try to create your domain like 1vn.com
install wordpress open source and having some error
Warning: require() [function.require]: open_basedir restriction in effect. File(./wp-blog-header.php) is not within the allowed path(s): (D:\Inetpub\vhostsvn.com\httpdocs\;C:\Windows\Temp\) in D:\Inetpub\vhosts\1vn.com\httpdocs\index.php on line 17
Look like The {DOCROOT} can't detected location of domain 1vn.com.
temporary solution for fix it, please change {DOCROOT}\ to root domain look like D:\Inetpub\vhosts\1vn.com\httpdocs\index.php
Please fix that, Parallels
First go to 'Hosting Package' settings and change the 'open_basedir' to this "D:\Inetpub\;C:\Windows\Temp\". Fix, no?
Second your lines contain typo's. :]
Third please tell me how I can export these settings so that I can place this file on Plesk right here right now.
Greets,
MikeRadian FIX :D
... BORING ...
"This forum requires that you wait 300 seconds between posts. Please try again in 31 seconds."
"This forum requires that you wait 300 seconds between posts. Please try again in 12 seconds."
"This forum requires that you wait 300 seconds between posts. Please try again in 4 seconds."
