    https://survey.webpros.com/
  • On Plesk for Linux mod_status is disabled on upgrades to improve Apache security.
    This is a one-time operation that occurs during an upgrade. You can manually enable mod_status later if needed.
Problem with Domain
R
RoxanneW
Parellel Plesk 9.5.2 Linux 2.6.18-028stab070.7 Virtual Server
PROBLEM: Removing domain from plesk panel apparently didn't remove pertinent DNS information and now the domain does not resolve elsewhere
ANY ADDITIONAL INFORMATION: below
I'm having trouble removing domain information from Plesk.
Essentially I once added a particular domain to the plesk panel. Later I decided to put this site within a multi-blog wordpress setup (several other domain mapped sites are working on this same setup currently), so I removed the domain from the panel and changed the DNS settings with the domain host (I have always left DNS settings with the host).
Now, however, for some reason I get a search page each time I try to access this domain. All of the settings on the hosting end are correct (and I verified with the host that no other issues were going on at that end) but still no luck. This has been days, so its not an issue of allowing the URL to change throughout the system.
I'm being told that this is an issue on my server and that somehow plesk has changed settings that now I'm unable to revert. Anyone have some idea of where/how I could revert these DNS settings so the domain will work properly?
Thanks to anyone who might have had this same issue and can help :)
