• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
Problem with horde webmail
J
JobHunter
I am running plesk 8.4 on a linux vps server. I am having an issue logging into webmail, when I go to webmail.mydomain.com I get the horde webmail login page. If I put the wrong user name and pass in, it tells me it is incorrect. If I put in the correct username and pass, it goes to a redirect.php page that just says page cannot be found. Any suggestions?
Thanks,
JobHunter
Try doing /usr/local/psa/admin/sbin/websrvmng -v -a
If you still experiencing the same problem after this, did you check horde logs to see if its shows any clue?
