Issue Problem with mariadb
FindYanot
Hello all, i have a problem with maria db.
System: Centos 7 64
After DDOS attack, maria db does not start.
I reboot server and i got this error:
I tried "service mariadb restart"
Code:
May 10 18:05:39 hostname mariadb-prepare-db-dir[5195]: rm: cannot remove ‘/var/lib/mysql/domains/hostname/.discovered/backup_info_1704060007’: Permission denied
May 10 18:05:39 hostname mariadb-prepare-db-dir[5195]: rm: cannot remove ‘/var/lib/mysql/domains/hostname/.discovered/backup_info_1704070007’: Permission denied
May 10 18:05:39 hostname mariadb-prepare-db-dir[5195]: rm: cannot remove ‘/var/lib/mysql/domains/hostname/.discovered/backup_info_1703290007’: Permission denied
May 10 18:05:39 hostname mariadb-prepare-db-dir[5195]: rm: cannot remove ‘/var/lib/mysql/mysql.daily.dump.0.gz’: Permission denied
May 10 18:05:39 hostname mariadb-prepare-db-dir[5195]: rm: cannot remove ‘/var/lib/mysql/mysql.daily.dump.1.gz’: Permission denied
May 10 18:05:39 hostname mariadb-prepare-db-dir[5195]: rm: cannot remove ‘/var/lib/mysql/mysql.daily.dump.2.gz’: Permission denied
May 10 18:05:39 hostname systemd[1]: mariadb.service: control process exited, code=exited status=1
May 10 18:05:39 hostname systemd[1]: Failed to start MariaDB database server.
May 10 18:05:39 hostname systemd[1]: Unit mariadb.service entered failed state.
May 10 18:05:39 hostname systemd[1]: mariadb.service failed.
Server domain changed to "hostname".
How to fix it?
Hi FindYanot,
pls. make sure, that you add the corresponding VERSION, if you desire help for a third party software, which is supported by Plesk and the very first information should be always the output if the command "plesk version" ( logged in as user "root" over SSH ).
In some cases, the Plesk REPAIR UTILITY can help to solve issues ( => Plesk Repair Utility )
Example command:
Code:
plesk repair db -y -v
... where the option string "-y" can be as well replaced with "-n" to do a so called "dry-run", without any repairs. ;)
