Issue Problems running NODE
DaniloVaron
AlmaLinux 9.2
Plesk Obsidian 18.0.56
I have problems uploading a web page with node
First I got this error
/usr/share/passenger/helper-scripts/node-loader.js:80
return originalRequire.apply(this, arguments);
Error [ERR_REQUIRE_ESM]: require() of ES Module /var/www/vhosts/deunacolombia.com/desarrollo.deunacolombia.com/deunacolombia-node/index.js from /usr/share/passenger/helper-scripts/node-loader.js not supported.
Instead change the require of index.js in /usr/share/passenger/helper-scripts/node-loader.js to a dynamic import() which is available in all CommonJS modules.
at Module.require (/usr/share/passenger/helper-scripts/node-loader.js:80:25)
at loadApplication (/usr/share/passenger/helper-scripts/node-loader.js:243:2)
at setupEnvironment (/usr/share/passenger/helper-scripts/node-loader.js:214:2)
at Object.<anonymous> (/usr/share/passenger/helper-scripts/node-loader.js:133:1) {
code: 'ERR_REQUIRE_ESM'
I tried a workaround from the same forum by creating an index.cjs file containing
import('./index.js').then(() => console.log('@@@@@@@ WORKED')).catch(e => console.log('@@@@@ @@ FAILED', e.message, e.stack));
making sure that the executable was that file.
Now the page has a 504 error
I use .ejs as templates and the page views are located here...
Does anyone have a solution please
Thanks
Thanks
The "document root" file is in..
In this folder are located all the views of the web page.
Solution:
I found the solution here:
Followed these steps and solved it.
  1. Create loader.cjs in your root file.
  2. Import your main file dynamically into the loader.cjs:
async function loadApp() {
await import('./index.js');
loadApp();
3. Go to your Node App in cPanel
4. In the "Application startup file", replace your main file with loader.cjs
5. Save and restart your app.
(if it doesn't work, destroy the project, then delete all files in the file manager and follow these steps again)
