• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
Problems with CHMOD on subdomain
V
vaida.dan
It seems I encountered an issue while installing a CMS in a subdomain. Lets take for example Wordpress. I've copied all the files required for the installation in the folder subdomains/wp/httpdocs/. Everything runs smoothly until the CMS needs to create a config.php file in order to finish the installation process. It says that the files and folders permissions are set wrong.
I only managed to install the CMS after manually setting the chmod to 777 to httpdocs folder. That is not a viable solution in my case.
I believe there are some problems with the owner group and apache. I have also heard that installing suPHP module might fix the problem. Are there any other solutions to this problem ?
