    https://survey.webpros.com/
Problems with Subdomains
C
CRNovalis
Hi!
I doesn't found anything with search, so i will write it here:
Is it possible, to define a Path for a Subdomain?
For example:
Subdomain: forum.domain.de
Path: domain.de/forum/images
The only thing i found is, to create a subdomain, and this domain create a new folder. but i would create a subdomain on a exist folder.
i hope you understand my problem. sorry for the bad english
best regards crnovalis
oh yeah.. that would be cool... i mean why is plesk so folder fixed? confixx is in this way much better.. you just had your physical hosting and could define everything you want yourself...
folder fixed is correct. what happend, wenn you would link a subdomain to an extern location? with PLESK it doesn't work
its kinda ridiculous.. i mean.. PLESK is much more expensive.. i think it should have the same comfortable functions as confixx has at least...
