S
stelman
Greetings
We are running a CentOs 6.0 with Plesk 10 on it. Our machine was probably hacked since the services stopped working and when I finally got a console I found out that a chmod 777 / -R was executed. So I have managed to restore Plesk and mysql functionality. The sites are all working again. However we have got a problem with qmail and I have researched a lot about it. I found replies in these forums about our problem but they are posted back in 2006 in old plesk panel for linux archived forums.
So here goes.
When i sent an email from outside to qmail I get back
SMTP Protocol Returned a Permanent Error 554 mail server permanently rejected message (#5.3.0
Also in the /usr/local/psa/var/log/maillog I get the following errors
I have looked a lot about sumbitter error code 62 but I can't pinpoint the problem. Also inside /usr/local/psa/handlers/before-queue there is no recipient directory. Should it be or this is just something temporary that's being created upon a mail delivery to an inbox?
If it's not the right section to post this please point me to the right one
Thank You and Best Regards
So here goes.
www /var/qmail/bin/relaylock[1952]: /var/qmail/bin/relaylock: mail from xxx.xxx.xxx.xxx:2863 (mail.server.com)
www qmail-queue-handlers[1955]: Handlers Filter before-queue for qmail started ...
www qmail-queue-handlers[1955]: from=mail.domain.com
www qmail-queue-handlers[1955]: [email protected]
www qmail-queue-handlers[1955]: hook_dir = '/usr/local/psa/handlers/before-queue'
www qmail-queue-handlers[1955]: call_handlers: call executable = '/usr/local/psa/handlers/info/10-spf-mcBz8C/executable'
www spf filter[1956]: Starting spf filter...
www spf filter[1956]: SPF result: pass
www spf filter[1956]: SPF status: PASS
www qmail-queue-handlers[1955]: handlers_stderr: PASS
www qmail-queue-handlers[1955]: call_handlers: PASS during call '/usr/local/psa/handlers/info/10-spf-mcBz8C/executable' handler
www qmail-queue-handlers[1955]: recipient[3] = '[email protected]'
www qmail-queue-handlers[1955]: handlers dir = '/usr/local/psa/handlers/before-queue/recipient/[email protected]'
www qmail-queue-handlers[1955]: starter: submitter[1957] with error code 62
www qmail-queue-handlers[1955]: mailsend: wait for submitter failed
www qmail-queue-handlers[1955]: cannot reinject message to mail system
