• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • Support for BIND DNS has been removed from Plesk for Windows due to security and maintenance risks.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
Slow (30 sec) response to incoming SMTP connection
R
ranageman
Incoming SMTP connections are always taking 30 seconds, or just over, to connect. This is causing problems with some senders who have their timeout set to 30 seconds.
While waiting, the following process is running:
root 30626 25648 0 12:14 ? 00:00:00 tcp-env /var/qmail/bin/relaylock /var/qmail/bin/qmail-smtpd /var/qmail/bin/smtp_auth /var/qmail/bin/true /var/qmail/bin/cmd5checkpw /var/qmail/bin/true
Here is a debug log from a sender with a simple Perl Net::SMTP connect:
[dan@frame-1 bin]$ time ./smtp_test.pl
Net::SMTP>>> Net::SMTP(2.26)
Net::SMTP>>> Net::Cmd(2.24)
Net::SMTP>>> Exporter(5.566)
Net::SMTP>>> IO::Socket::INET(1.26)
Net::SMTP>>> IO::Socket(1.27)
Net::SMTP>>> IO::Handle(1.21)
<wait 30 secs>
Net::SMTP=GLOB(0x127128)<<< 220 39151.vs.webtropia.com ESMTP
..etc.
Connection is successful.
What might be waiting 30 seconds here?
/ranageman
Ha - fixed it myself :)
Put a "-R" as the first item in "server_args" in /etc/xinet.d/smtp_psa, and restarted xinetd.
Apparently smtpd will otherwise wait up to 30s for (useless) remote info from the incoming server, and in my case here, the incoming server timeout was set to about the same....
