W
WiReDWolF
On debian 4.
Attempted to upgrade from 8.6 to 9.0
Solved a number of problems but can't get past this one:
Setting up sw-sso (2.2-r3488) ...
DB file already exists. Let's check for upgrade
DB update failed (Can not upgrade. DB version '1' is too old. You should upgrade it manually up to '4' at least). See log file for detailed output.
dpkg: error processing sw-sso (--configure):
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
sw-sso
E: Sub-process /usr/bin/dpkg returned an error code (1)
Researching how to upgrade the versioning of the DB - it shows the Schema is version 1, needs 4 according to this error message - but the sso logs show that it's actually looking for version 7. Unfortunately there is nothing that I can find anywhere to help me update the versioning manually. The version of sw-sso is apparently current, just not the DB schema...
Any ideas?
sw-sso
Any ideas?
