Resolved use nodejs and problem with express routing
rmazarlou
I upload and extract this GitHub - plesk/node-express: A simple Express-based app to test Node.js support. project on /httpdocs folder and change Application
Startup File to server.js and after browsing the domain like this : http://www.mydomain.com and see
Express welcome message
but when I want get users with this url http://www.mydomain.com/users server give me this error :
HTTP Error 404.0 - Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
I solve it :)
just add rewrite rule and handlers in web.config like this :
<handlers>
<add name="iisnode" path="server.js" verb="*" modules="iisnode" />
</handlers>
<rewrite>
<rules>
<rule name="myapp">
<match url="/*" />
<action type="Rewrite" url="server.js" />
</rule>
<!-- Don't interfere with requests for node-inspector debugging -->
<rule name="NodeInspector" patternSyntax="ECMAScript" stopProcessing="true">
<match url="^server.js\/debug[\/]?" />
</rule>
</rules>
</rewrite>
<directoryBrowse enabled="true" />
<iisnode devErrorsEnabled="true" debuggingEnabled="true" loggingEnabled="false" nodeProcessCommandLine="C:\Program Files\nodejs\node.exe" />
I solve it :)
<handlers>
</handlers>
<rewrite>
<rules>
<rule name="myapp">
<match url="/*" />
</rule>
</rule>
</rules>
</rewrite>
Dear rmazarlou, I'd like to thank you for this post. Spent days dealing with nodejs on windows plesk in vain. Thanks to this article, i made it wonderfully, thanks again.
Hey People,
i found this question here and tried the solution but i still have some problems after that change.
The url: test.mydomain.com gives me a repsone that my express server is started
i also get a response if i try the url "test.mydomain.com/api/hello"
but when i try to call "test.mydomain.com/api/auth/user/login" it is giving only a 404 back from plesk.
My rewrite rules:
Code:
<?xml version="1.0" encoding="UTF-8"?>
<configuration>
  <system.webServer>
    <httpErrors>
      <remove statusCode="400" />
      <error statusCode="400" path="C:\Inetpub\vhosts\mydomain.com\error_docs\bad_request.html" />
      <remove statusCode="401" />
      <error statusCode="401" path="C:\Inetpub\vhosts\mydomain.com\error_docs\unauthorized.html" />
      <remove statusCode="403" />
      <error statusCode="403" path="C:\Inetpub\vhosts\mydomain.com\error_docs\forbidden.html" />
      <remove statusCode="404" />
      <error statusCode="404" path="C:\Inetpub\vhosts\mydomain.com\error_docs\not_found.html" />
      <remove statusCode="405" />
      <error statusCode="405" path="C:\Inetpub\vhosts\mydomain.com\error_docs\method_not_allowed.html" />
      <remove statusCode="406" />
      <error statusCode="406" path="C:\Inetpub\vhosts\mydomain.com\error_docs\not_acceptable.html" />
      <remove statusCode="407" />
      <error statusCode="407" path="C:\Inetpub\vhosts\mydomain.com\error_docs\proxy_authentication_required.html" />
      <remove statusCode="412" />
      <error statusCode="412" path="C:\Inetpub\vhosts\mydomain.com\error_docs\precondition_failed.html" />
      <remove statusCode="414" />
      <error statusCode="414" path="C:\Inetpub\vhosts\mydomain.com\error_docs\request-uri_too_long.html" />
      <remove statusCode="415" />
      <error statusCode="415" path="C:\Inetpub\vhosts\mydomain.com\error_docs\unsupported_media_type.html" />
      <remove statusCode="500" />
      <error statusCode="500" path="C:\Inetpub\vhosts\mydomain.com\error_docs\internal_server_error.html" />
      <remove statusCode="501" />
      <error statusCode="501" path="C:\Inetpub\vhosts\mydomain.com\error_docs\not_implemented.html" />
      <remove statusCode="502" />
      <error statusCode="502" path="C:\Inetpub\vhosts\mydomain.com\error_docs\bad_gateway.html" />
      <remove statusCode="503" />
      <error statusCode="503" path="C:\Inetpub\vhosts\mydomain.com\error_docs\maintenance.html" />
    </httpErrors>
    <tracing>
      <traceFailedRequests>
        <clear />
      </traceFailedRequests>
    </tracing>
    <handlers>
<add name="iisnode" path="index.js" verb="*" modules="iisnode" />
</handlers>
<rewrite>
<rules>
<rule name="myapp">
<match url="/*" />
<action type="Rewrite" url="index.js" />
</rule>
<match url="^index.js\/debug[\/]?" />
</rule>
</rules>
</rewrite>
  </system.webServer>
  <system.web>
    <compilation tempDirectory="C:\Inetpub\vhosts\mydomain.com\tmp" />
  </system.web>
</configuration>
