Question Websocket Problem on wss
Javad
I'm having troubles connecting to a WebSocket server via WebSocket Secure connection (wss://) from the browser. Standard connections (ws://) work fine.
To solve this problem in the ispmanager, I used the following code in the site config file and the problem was resolved:
Code:
ProxyPass /echobot ws://coinbazaar.io:9000/echobot
I added the above code in the Additional Apache directives section in plesk. But this method did not resolve my problem and it occurs with error.
Error:
Code:
WebSocket connection to 'wss://coinbazaar.io:9000/echobot' failed: WebSocket opening handshake timed out
I have same problem!
Try to connect from client side to wss://example.com/ws
And want to proxy connection to ws// , because my server side is non secure
My apache additional dirrectives:
SSLProxyEngine On
RewriteEngine on
ProxyRequests Off
ProxyPreserveHost on
ProxyPass /ws/ ws://examplae.com:8090/ws
ProxyPassReverse /ws/ ws://examplae.com:8090/ws
It returns 500 error and:
"AH01144: No protocol handler was valid for the URL /ws/. If you are using a DSO version of mod_proxy, make sure the proxy submodules are included in the configuration using LoadModule."
All modules in Apache are enabled.
Javad, did you solve problem? Help anybody please
Code:
Error:
Code:
Dear Javad. After 5 days of coding I found totally solution. Use nginx proxy, not apache. It work fine for me
location /echobot/ {
proxy_pass http://echobot:8090;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
