[11.09] Clean install, postfix milter / psa-pc-remote not running!!
ScuL81
Hi I'm running
Parallels Plesk 11.0.9 Update #60, last updated at April 8, 2014 11:03 AM on CentOS 6.5 (Final)
The problem I'm having is despite correct configuration, the milter service (I believe ran by psa-pc-remote process) is not active.
A portscan of port 12768 shows no service running.
Conclusively this generates the following error:
Apr 9 22:34:07 adm postfix/cleanup[8975]: warning: connect to Milter service inet:127.0.0.1:12768: Connection refused
Apr 9 22:34:07 adm postfix/cleanup[8975]: CB9F518C0414: milter-reject: CONNECT from localhost[127.0.0.1]: 4.7.1 Service unavailable - try again later; from=<[email protected]>
Running the mail checker generates:
/usr/local/psa/admin/sbin/mchk
[sudo] password for scul:
==> Checking for: mailsrv_conf_init... ok
==> Checking for: mail_handlers_init... ok
==> Checking for: mailsrv_entities_dump... ok
==> Checking for: mail_admin_aliases... ok
==> Checking for: mail_auth_dump... ok
==> Checking for: mailman_lists_dump... ok
==> Checking for: mail_kav8_restore... ok
==> Checking for: mail_responder_restore... ok
==> Checking for: mail_postfix_transport_restore... ok
==> Checking for: mail_spam_restore... not exists
==> Checking for: mail_grey_restore... ok
==> Checking for: mail_mailbox_restore... ok
==> Checking for: mail_spf_restore... ok
==> Checking for: mail_dk_restore... ok
==> Checking for: mail_drweb_restore... not exists
This is a clean install, the server is 2 days old.
Any reason what is going wrong?
I have now blanked out the lines
# smtpd_milters = inet:127.0.0.1:12768
# non_smtpd_milters = inet:127.0.0.1:12768
in /etc/postfix/main.cf
This allows me to send e-mail. As soon as I enable them, the errors above are generated and the server can not send any mail.
This is indeed the correct issue, however those services do not function
Code:
[scul@adm ~]$ /etc/init.d/ctasd_initd start
-bash: /etc/init.d/ctasd_initd: No such file or directory
[scul@adm ~]$  /etc/init.d/ctmilter_initd start
-bash: /etc/init.d/ctmilter_initd: No such file or directory
