Resolved add and Remove Product Components“ not work on webinterface
fabian koeppel
Basic Pleskian
i have 3 onyx Server on ubuntu 16.04 All Plesk install whit one click installation
sh <(curl https://autoinstall.plesk.com/one-click-installer || wget -O - https://autoinstall.plesk.com/one-click-installer)
butt on all 3 Server the „add and Remove Product Components“ not work. ( https://IP:8447 Webinterface )
No matter what I install it always comes on error log :
[2016-12-15 09:59:36.504388] Install command successfully completed
[2016-12-15 09:59:36.505424] Release PLESK_17_0_17 is actual
[2016-12-15 09:59:36.505508] Release PLESK_17_0_17 is currently installed
[2016-12-15 09:59:36.505620] Patch for plesk 17.0.17 will be installed.
[2016-12-15 09:59:36.505670] Patches werden installiert...
[2016-12-15 09:59:36.516357] Unexpected exception caught
on SSH whit /usr/local/psa/admin/bin/autoinstaller --select-product-id plesk --select-release-current --install-component xxxxxxxx
works perfectly on al 3 Server.
Is this a Bug from onyx and ubuntu 16.04 Or only I have the problem? Comically that the webgui on all servers does not go.
Oh very fast good support. Thank you very much. It works now. Your link has helped. I have also Ubuntu installed in English but Plesk in German. This has helped:
To configure locale, edit /etc/locale.gen, uncomment the de_DE.UTF-8 UTF-8 line in it. Then run locale-gen:
thanks
