• The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
Another wildcard subdomain problem
S
SergheiH
Hi
I have 5 subdomains for my main domain.
The 3rd subdomain I've created to serve as a catch all subdomain.
Of course I've added in it's "vhost.conf" file the "ServerAlias *.domain.com" line and I read the KB from here: http://kb.odin.com/en/2239 .
But when I've added two more subdomains the catch all subdomain was catchig them also, even if my "catch all" subdomain name starts with last letter from alphabet "zz-wildcard".
This is happening because the rules in the "httpd.include" file are ordered by date of adding the subdomain and not alphabetical.
Can please someone suggest a solution for this?
Because right now I have only 2 options:
1. editing manually the "httpd.include" file each time I update some subdomain from Plesk, or
2. deleting the subdomain "zz-wildcard" and creating it again
Thanks
Got it
Found the solution...
In the mean while my Plesk version was updated to 9.5.1 but I guess the same thing would work for any version.
Well, the solution was simple: to edit Plesk's database "psa", table "subdomains".
I've checked if there is no connection between subdomain's IDs and other tables, and apparently there are no JOINs.
Then I've changed the ID of my "catch all" subdomain to be greater than other's. :)
Pretty simple...
Now my "zz-wildcard" subdomain's rules are the last in the "httpd.include" file and also the last in the list of subdomains displayed in Plesk and everything works perfect.
