• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • Support for BIND DNS has been removed from Plesk for Windows due to security and maintenance risks.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
APS Catalog error: Recv failure: Connection was reset.
Raymond van driel
Plesk 12 Trial, Win2012. VMware player, network bridged.
Cannot access Application Catalog. :- "APS Catalog error: Recv failure: Connection was reset."
If I wget, curl, or attempt to browse from the server to the aps repository (http://apscatalog.com) it fails. On my vmware host it works. Other sites work on the guest.
However https://apscatalog.com (ie, via HTTPS://) works on guest, so not DNS.
Tried disabling firewall.
Not sure if this is a VMware, W2012, firewall, plesk, thing...
Thought maybe i could workaround by setting the repository to use SSL - where is this setting?
Thanks,
Ray.
