Asp.net Ajax and System.Web.Extensions.dll
B
budwaiser
someone knows if there are problems to install Asp.net Ajax on Plesk 8.2.x?
I need
also. Is it only included into Ajax or i can install it in a different way?
Thank you
There are no any difficulties.
Just install asp.net ajax and use it.
Also check the article
i'm not sure about System.Web.Extensions.dll.
I think it can be installed anyware.
But if your site is not working, you can place this dll into bin directory of the domain.
Thank you for your help.
Searching on the net i have found System.Web.Extensions.dll only with Ajax package.
I don't know..
Thanks again
