• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • Support for BIND DNS has been removed from Plesk for Windows due to security and maintenance risks.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
Autoinstaller Problems after Upgrade to 8.1
L
Lurker
I did an upgrade from 8.01 to 8.1 using the autoinstaller recently, which was working well. Now there are some further updates for 8.1 listed in the updater, but when I try to install these updates I get a mail "Plesk autoupdate failure report".
I try to install these packages (via the Updater):
Component || Your release || Latest release || Status
Base packages of Plesk || Dec 12, 2006 || Dec 26, 2006 || An update is available
Plesk API [former Plesk Agent] || Sept 4, 2006 || Dec 26, 2006 || An update is available
Plesk Backup Manager || Dec 26, 2006 || Dec 26, 2006 || An update is available
Plesk migration manager || Sept 4, 2006 || Dec 26, 2006 || An update is available
The failure report contain this lines:
Getting packages to installation list:
Get packages to installation from selected component base
Get packages to installation from selected component backup-vz
Get packages to installation from selected component api
Get packages to installation from selected component pmm
resolve packages with apt-get
apt-get say following:
Reading Package Lists...
Building Dependency Tree...
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
psa-hotfix1: Depends: psa-8.0.1 but it is not installable
psa-migration-manager: Depends: db4.2-util but it is not going to be installed
Depends: libdb3-util but it is not going to be installed
catch error with message: Error while resolve packages by apt
ERROR: Error while resolve packages by apt
Check SElinux status after error:
Exit with ERROR status
Any idea what to do? Thanks a lot!
Kind regars,
Juergen
If you're comfortable with the console, you could try a fresh "apt-get update", then "apt-get -f install".
If that doesn't work, post what the response is, and can go from there.
Alternatively, i've seen some cases of debian + plesk where you just need to run the updater through the control panel multiple times.
Thanks for your feedback. I tried what you said, but it wasn't working again. This is the console output (shortened):
===> Installing phpMyAdmin
Trying to create pmadb... done
done
===> Installing /usr/lib/apache2/suexec2 replacement
This module is already enabled!
===> Cumulative upgrade has been started
ERROR while trying to upgrade SQL database from 800
Check the error reason(see log file: /tmp/psa_8.1.0_debian3.1.build81061129.22_upgrade.log), fix and try again
Aborting...
And this is the psa_8.1.0_debian3.1.build81061129.22_upgrade.log:
done
Leaving `diversion of /usr/lib/apache2/suexec2 to /usr/lib/apache2/suexec2.distr
ib by psa'
`/opt/psa/suexec/psa-suexec2' -> `/usr/lib/apache2/suexec2'
ERROR 1060 (42S21) at line 8: Duplicate column name 'fastcgi'
070106 11:33:01 INNODB MONITOR OUTPUT
Per second averages calculated from the last 50 seconds
SEMAPHORES
OS WAIT ARRAY INFO: reservation count 233, signal count 233
Mutex spin waits 2774, rounds 8864, OS waits 8
RW-shared spins 106, OS waits 53; RW-excl spins 171, OS waits 168
TRANSACTIONS
Trx id counter 0 426699
Purge done for trx's n:eek: < 0 426669 undo n:eek: < 0 0
History list length 52
Total number of lock structs in row lock hash table 0
LIST OF TRANSACTIONS FOR EACH SESSION:
---TRANSACTION 0 0, not started, process no 9782, OS thread id 107167754
MySQL thread id 6533, query id 283556 localhost admin
show innodb status
FILE I/O
I/O thread 0 state: waiting for i/o request (insert buffer thread)
I/O thread 1 state: waiting for i/o request (log thread)
I/O thread 2 state: waiting for i/o request (read thread)
I/O thread 3 state: waiting for i/o request (write thread)
Pending normal aio reads: 0, aio writes: 0,
ibuf aio reads: 0, log i/o's: 0, sync i/o's: 0
Pending flushes (fsync) log: 0; buffer pool: 0
3004 OS file reads, 229 OS file writes, 183 OS fsyncs
0.04 reads/s, 16384 avg bytes/read, 0.32 writes/s, 0.28 fsyncs/s
INSERT BUFFER AND ADAPTIVE HASH INDEX
Ibuf for space 0: size 1, free list len 5, seg size 7, is empty
0 inserts, 0 merged recs, 0 merges
Hash table size 34679, used cells 0, node heap has 1 buffer(s)
0.00 hash searches/s, 3.42 non-hash searches/s
LOG
Log sequence number 0 374066132
Log flushed up to 0 374066132
Last checkpoint at 0 374044769
0 pending log writes, 0 pending chkp writes
156 log i/o's done, 0.24 log i/o's/second
BUFFER POOL AND MEMORY
Total memory allocated 18639854; in additional pool allocated 1046400
Buffer pool size 512
Free buffers 0
Database pages 511
Modified db pages 23
Pending reads 0
Pending writes: LRU 0, flush list 0, single page 0
Pages read 5349, created 4, written 64
0.04 reads/s, 0.08 creates/s, 0.06 writes/s
Buffer pool hit rate 999 / 1000
ROW OPERATIONS
0 queries inside InnoDB, 0 queries in queue
Main thread process no. 24979, id 114696, state: sleeping
Number of rows inserted 23, updated 127, deleted 12, read 2250493
0.08 inserts/s, 0.04 updates/s, 0.00 deletes/s, 1.88 reads/s
END OF INNODB MONITOR OUTPUT
Aborting...
Any further idea? Thanks a lot!
Kind Regards,
Jürgen
Could you post all of the response from apt-get -f install?
It is working now: I did a restore from the backup I created before the upgrade to 8.1.
In the plesk interface updater there were two entries, 8.01 and 8.1. There were updates available for both.
The first time I did an update directly to 8.1, because I thought that this will include also all changes from 8.01. But this caused the problems i posted here.
After the restore I did first install all updates for 8.01, and after this I upgraded to 8.1. This was working well, an d I have not found any problems yet.
Cheers,
Lurker
